Results 1 to 15 of 15
    auto techniek's Avatar
    Mar 2017
    Default Audi A6 steering lock emulator problem
    I ve a Audi 2005 with steering defect. I read it on bench and write the file to ELV emulator.
    Car does not start
    Elv wih 3L40K EEPROM. I read somewhere that the dump need to be converted from 2k to 4k before write it to Emulator
    Here file from original ELV
    Jan 2018
  3. The Following User Says Thank You to bmujka For This Useful Post:
    auto techniek (4th April, 2024)
    Mar 2017
    I converted the 2kb file to 4 kb OL01Y with the converter above. Did write file to emulator with vvdi prog under J518 2010 0L01Y
    But car still dead.
    no clue what is wrong.
    ricked's Avatar
    Apr 2016
    Europe
    Quote Originally Posted by auto techniek View Post
    But car still dead.
    depents how you did get the car(in what state), im pretty sure what the problem is here....
    Mar 2017
    if you know what the problem is may be you can help.
    I ve never used a emulator before I use always second hands part and code online.
    The car start sometimes in the begin mostly not. The ELV was removed from his position and i saw some solder on the PCB. Someone did before me solder wires to the PCB.
    Quote Originally Posted by ricked View Post
    ricked's Avatar
    Apr 2016
    Europe
    so why use a shitty emulator if you have access to online coding??
    Mar 2017
    i have one emulator here and i don t have any secondhands parts. to order take time
    The question is how to solve this if you know what i did wrong
    ricked's Avatar
    Apr 2016
    Europe
    delete errors in elv as data is ok
  10. #9
    p1et's Avatar
    Oct 2013
    Did you solve the problem, is the emulator working OK?
  11. #10
    p1et's Avatar
    Oct 2013
    Which part number must be the same? Is it ok if I clone from one to another on photo? 2nd one Is original from car
  12. #11
    ricked's Avatar
    Apr 2016
    Europe
    Quote Originally Posted by p1et View Post
    part number 4F0905852B needs to be the same
    number 2.30 and 2.10 are software numbers so clone flash plus eeprom, if software number is the same you can copy eeprom only but then again always check if flash file is the same and not corrupt
  13. The Following User Says Thank You to ricked For This Useful Post:
    p1et (15th April, 2024)
  14. #12
    Mar 2017
    Yes
    This part nr you need to look for
    4F0905852B
  15. #13
    Mar 2017
    Remember when you program emulator or second hands ELV. Need first scan the car and delete all faults codes. Otherwise car wil not start.
    Verstuurd vanaf mijn CPH2359 met Tapatalk
  16. #14
    ricked's Avatar
    Apr 2016
    Europe
    like i did say before.....
  17. #15
    p1et's Avatar
    Oct 2013
    Emulator is working good, there was problem with ignition lock.
