Hi I have a 2020 Ford f350 Diesel Im attempting to correct. Can anyone help by chance? The chipset is a 93c86
The current is 296427.0 miles I need 136500.0 miles. If anyone can help correct or teach either would be appreciated.
and what year more o less you could be post the original file post, but you can do it by obd too
My mistake the attachment didnt post first time not in a .rar originally I tried obd my machine does work on 2020 f350 but for some reason the deisel would not take.
what tool you had used by obd?
test and report
AppolageticSoul (17th April, 2024)
obdstar odomaster
may be 12+ 8 gateway but there is the file post test and report
f350 2023 is 24c64 back the carstereo
your odomaster is update?
Worked perfect. Number as called for, all functions ok. Thank you everyone
yes its to date. It reads but doesnt write. The file you sent worked Thanks I was under the impression the 12+8 was just for chrysler dodge.
The file he posted worked. You talking about problems down the road? Everything tested worked good.
that is good
You will see.
His edit is garbage and the odometer will freeze. Not to mention the hours are completely wrong for the mileage.
He doesn't have a fkn clue.
