Results 1 to 7 of 7
    May 2024
    Default Delphi VCIs not communicating with vehicle after firmware upgrade.
    Hello gents, I have a problem with three delphi VCI clones. I downloaded version 2021.11 and tried to use it, since it is the only one working on Windows 11. When I plugged in the VCI, i told me I needed to upgrade the firmware (to 3201) for it to work.I did that and now none of my three delphi VCIs work properly. They say the vehicle is not responding. What is weird about them is that they do talk to the car, just not completely. I tried deleting the service light on my renault and it worked, but anything else from the ECU is not working. What can I do? Thanks.
    Aug 2020
    Quote Originally Posted by AdrianG View Post
    Buy a better single pcb vci. It sounds like you have double pcb and you need to use 1622 firmware. You can reinstall and select the 1622 firmware. Double pcb are junk and are only good up to 2017. There is no way to make them work better no matter what firmware you try. For the best quality single pcb email mhhhanstanz at gmail dot com
    This c4b 2021 is only a modified version or our original 2020.23 hence why it is for free
    HaynesPro 2025 online + AC/ Delphi 2022.02a available, message for where to get them!
    May 2024
    I installed version 2017 and tried firmware 1622 and still the same thing. I tried even more subcomponents and they work fine (testing instrument cluster,testing braking). What else can I try? Thanks.
    Aug 2020
    Try the c3b 21 with 1622 firmware. It gives you the option when you are installing what firmware to apply
    May 2024
    Ok. Ive read that I could try WOW Wurth for firmware change as autocom/delphi doesnt upload all the necessary files. If your solution fails, could I try this? Thanks for the replies!
    Aug 2020
    Thats not true. The 1622 usually comes with extra files to work with wow. These extra files will not make a difference in the autocom. You can try the wow if the cars are pre 2015
    May 2024
    Hello, I have stopped working due to Orthodox Easter. I fixed them following your advice,thank you.
  8. The Following User Says Thank You to AdrianG For This Useful Post:
    crouchinggerbil (8th May, 2024)
