Results 1 to 15 of 28
Thread: Op com problem
    May 2024
    Default Op com problem
    Hello again.
    Facing this problem....test interface passed,diagnostics,auto vehicle identification,kwp,
    ecu not reply...
    when i choose any other options got interface communication error or interface not powered from car.
    This happen even the interface is connected to obd or not.
    Anyone facing same issue?
    Any ideas are acceptable
    Thanks a lot.
    WALES
    Quote Originally Posted by leonidasleon View Post
    Hello again.
    ecu not reply...
    Thanks a lot.
    Possible faulty OPCOM, try another
    also look at driver, must be for the OPCOM in use
    wbr
  3. The Following User Says Thank You to shooting For This Useful Post:
    leonidasleon (13th May, 2024)
    May 2024
    Thanks for the reply.
    You mean the software?
    It's from phantomel.
    How can I check for the drivers?
    Sorry for asking always but I am new to this.
    Oct 2018
    Romania
    Sure you can use the phantomel software.
    Once you attach the OPCOM device, please install the drivers as can be found where the software is installed. Example: "C:\Program Files (x86)\OP-COM Multi\your_version\Drivers"
  6. The Following User Says Thank You to workbattery For This Useful Post:
    leonidasleon (14th May, 2024)
    WALES
    In "Device Manager" check your driver
    wbr
  8. The Following User Says Thank You to shooting For This Useful Post:
  9. #6
    May 2024
    Quote Originally Posted by shooting View Post
    wbr
    you think is ok?
  10. #7
    WALES
    you think is ok?
    Driver looks ok.....
    Post your driver and I will try it on one of my V1.99 tools
    wbr
  11. The Following User Says Thank You to shooting For This Useful Post:
  12. #8
    May 2024
    by the way i found that at the device manager.Maybe this is the problem?unnamed (1).jpg..
  13. #9
    May 2024
    Here they are ...
  14. #10
    WALES
    This is in your language, we don't speak your language.
    wbr
  15. #11
    May 2024
    Hey my friend. In the second box is I your language. Not the highlighted. Thanks again.
  16. #12
    WALES
    Here they are ...
    This is 05/07/2021 driver, your picture shows 2013 driver
    Try with this driver
    wbr
  17. #13
    May 2024
    Thnks a lot my friend but it ask for password when i try to extract.
  18. #14
    Dec 2014
    PL
    Browse this topic post #18 and read what Fantomel wrote. There you also have one link to all Opcom software on YANDEX. And a program to remove inappropriate drivers.
    Drivers cannot be newer than July 14, 2013 (January 18, 2013 and older are good). If you use newer ones, each Fantomels Opcom software will request activation.
    In my opinion your interface is of very poor quality and it should work with Opcom 08 2010 or it is already broken.
    https://www.digital-kaos.co.uk/forum...ighlight=opcom
    + I added down PDF's for CH-CAN modification and also if you like printed boards the project for it.
    Enjoy
    Fantomel
  19. The Following User Says Thank You to Mario6 For This Useful Post:
    leonidasleon (15th May, 2024)
  20. #15
    WALES
    Your password was sent to your private messages....
    wbr
  21. The Following User Says Thank You to shooting For This Useful Post:
    leonidasleon (2nd June, 2024)
