Results 1 to 7 of 7
    May 2011
    Default GOLF VII MED 17.5.25 0 261 S09 531 immo off
    Hi Guys. Please immo of in ecu
    med17.5.25
    0261S09531
    04E 907 309AF
    Best Regards.
    Aug 2023
    Default IMMO OFF
    Try this.
    thx & rep = pass
    ​​If I was helpful, DON't forget the "THANK YOU" and "REPUTATIONt" buttons!
  3. The Following User Says Thank You to elgarage For This Useful Post:
    Rawwen (21st May, 2024)
    May 2011
    Quote Originally Posted by elgarage View Post
    Try this.
    thx & rep = pass
    Car starts just once on Your file. After that not crank.
    aboelgood's Avatar
    Feb 2023
    Egypt
    Quote Originally Posted by Rawwen View Post
    Not Easy Doing Immo Off this Ecu , Not Found Free working Solution
    Nothing For Free I See That From All ...
    I will give the file for free for whatever I want ...
    Hayssam1's Avatar
    Germany
    med17.5.25
    0261S09531
    04E 907 309AF
    Best Regards.
    VIN: WVWZZZ6RZFY242355
    CS: 1BD40000000000000000000000000000
    MAC: 31D80000
    POWERCLASS: 11
    FAZIT: BPG-81014.01.1512600058
    please try this file and let me know
    Please Press Thanks Button and Reput if i helped !
    May 2011
    Quote Originally Posted by Hayssam1 View Post
    MAC: 31D80000
    POWERCLASS: 11
    Hi. Thank's for help.
    Same situation, car start only once after write files.
    I think its cks problem, can You give me file without chks? I will let FLEX to make it. What do You think?
    kuebk's Avatar
    Feb 2016
    Here you go.
    VAG immo solutions (clone, immo off) MEDC17, SIMOS, BCM2 (eeprom fix), ELV (P160A fix), INVCON.
  9. The Following User Says Thank You to kuebk For This Useful Post:
    Rawwen (24th May, 2024)
