Results 1 to 5 of 5
    Feb 2019
    Nederland
    Default RNS510 Black screen
    RNS510 S29AL016_P_ver_H10_5238.rarHi,
    I have RNS510 with black screen mistake, can someone help with S29AL016D dump?
    1T0035680P SW5238 HW10
    Or if possible repair mine
    At first it froze and a message appeared on the screen in German: "die gewünschte sprache wird geladen"
    I tried updating the firmware from CD 5238 and a message immediately appeared SWL Error.Then I'm in the setconfig I erase nand flash.now even the logo doesn't appear but the disk is accepted and again SWL Error
    Thanks in advance
  2. The Following User Says Thank You to duzaven For This Useful Post:
    0xSONNY (17th December, 2024)
  3. #2
    dec123ua's Avatar
    Nov 2015
    Kiev, Ukraine
    connect UART and check start up log
    i hope you need reinstall software via SWL mode only
  4. The Following User Says Thank You to dec123ua For This Useful Post:
    duzaven (1st June, 2024)
  5. #3
    Feb 2019
    Nederland
    ancouver CSL v007.007.006
    Boostrap v7.7.7
    [1] Second UART disabled due to hardware configuration.
    Starting Boot Loader 1...
    WQ_BU@##%
    ---- RAM-INIT +: InfoLog ILstart fffc0000 ILend fffe0000 0 [ms]
    ---- RAM-INIT -: InfoLog ILstart fffe0000 ILend fffe0000 0 [ms]
    61681027 NMBH_Init - Assuming in Bootloader
    [tBoot(0):50010806] Activating VERIFY for I/O on device /wtil!
    [tBoot(0):50013804] created flash partition /wtil with sector size 4096
    NMBH_Init: setting function pointers
    +++ task : startBlMain id FFDD6A88 prio 00000001
    -> BL 50 [ms] : Start Application : call BlMain()
    >BL [50 ms]:+++ task : Controll_Loop id FFDDAD20 prio 0000005B
    >BL [50 ms]: p32ShPointer_SharedMemory = F0701EE0
    >BL [50 ms]:
    >BL [50 ms]:==========================================
    >BL [50 ms]: (c) 2005 Siemens VDO Automotive AG
    >BL [50 ms]: CP-X Platform Bootloader
    >BL [50 ms]: Version : 13.55.05
    >BL [50 ms]: Date : Sep 25 2012
    >BL [50 ms]: Time : 11:33:08
    >BL [50 ms]:THIS VERSION IS AN OFFICIAL DELIVERY
    >BL [66 ms]:==========================================
    >BL [66 ms]:===== Mainprint-Info =====================
    >BL [66 ms]: item len value
    >BL [66 ms]: PlatformId 00000004: 00010002
    >BL [66 ms]: ProductId 00000004: 00020101
    >BL [83 ms]: ModuleId 00000004: 00010002
    >BL [83 ms]: HardwareId 00000004: FFFFFFFF
    >BL [83 ms]: ProductionDate 00000004: 20130228
    >BL [83 ms]: Serial-Number 0000000F:
    >BL [83 ms]: A2C-Number 0000000F:
    >BL [100 ms]:==========================================
    >BL [100 ms]:ShowReleaseInfos
    >BL [166 ms]:BuildFlashTable
    >BL [166 ms]:FIB BASEADDR 00080000 SIZE 06D80000
    >BL [166 ms]:SWL BASEADDR 06E80000 SIZE 00480000
    >BL [166 ms]:FFS BASEADDR 07E00000 SIZE 00000000
    >BL [166 ms]: first Infolog access
    >BL [166 ms]:BL_IlRead id 00000006 vers 00005C0F lastDataAdr 00005FAF
    >BL [166 ms]:BL_IlRead id 00000009 vers 00005C10 lastDataAdr 00005FAF
    >BL [183 ms]:IL_Check done: Status IL1 00000000 IL2 00000000
    >BL [183 ms]:BL_IlRead id 00000009 vers 00005C10 lastDataAdr 00005FAF
    >BL [200 ms]:task ipcVuc id FFDE3170 prio 0000005A
    >BL [200 ms]:ipcVuc_registryFunction
    61400130 Opened read channel
    61400131 Opened write channel
    610A1900 ipcVuc_startUp succeeded
    >BL [200 ms]:ipcVuc_startUp [00000000]
    >BL [200 ms]:FB_DynReg : bFblockId 000000F0 bInstId 00000030
    >BL [200 ms]:FB_DynReg : bFblockId 00000007 bInstId 00000020
    >BL [200 ms]: FB_RTC_Init :
    >BL [200 ms]: task : Clock_Loop id FFDEE8F0 prio 00000028
    >BL [200 ms]rive: StartTask
    >BL [216 ms]:SIPC_LIGHT_FKT_ID_HOST_READY
    >BL [216 ms]:IPC_LIGHT_FKT_ID_MONITORING_PHASE_START
    >BL [216 ms]rive:
    >BL [233 ms]:IL_UserRead : valid InfoLog in RAM found
    >BL [233 ms]:SplashScreen : SplashLogo_GetCustomerVariant : get Logo-Data
    >BL [233 ms]:SplashScreen : SplashLogo_GetCodingData
    >BL [233 ms]:SplashScreen : SplashLogo_GetCodingData : DataPointer=FFDF2E6A Len=0000000C Copied=00000000
    >BL [233 ms]:SplashScreen : SplashLogo_GetCodingData : Logo info : 0000012C 0000015E 00000001 00000000 000000FF 000000FF 00000000 000000FF 10020001
    >BL [250 ms]:SplashScreen : GrafikInitShowSplashScreen : DisplayType = 00021675 CustomerVariant = 00000001
    >BL [250 ms]:
    SplashScreen : GrafikInitShowSplashScreen : No valid SplashScreen image available!!!]
    A1683041 Image 15 is not stored
    >BL [283 ms]:SplashScreen : GrafikInitShowSplashScreen : SplashScreen copied into RAM
    614E6001 Graphic HW-Info: Display=800x480 (3), Profile=0 [old=0, new=31/0xfffffffe, IL=0x0]
    613D0110 Present devices: 1/1/0 [0]
    >BL [316 ms]rive: DRV_ATAPI_DrvCreate done
    614E5000 BL : HW Info DisplayType : 3 CoralPA_Address = 0x93fd0000 DCM3 = 0x10 VDP = 0x1df01ec
    614E5000 > --->> VIDEO MEMORY SIZE = 16 MB <<---
    >BL [316 ms]:SplashScreen : GrafikInitShowSplashScreen : Initialize the GDC
    >BL [316 ms]:SplashScreen : GetLogoData
    >BL [316 ms]:SplashScreen : GetLogoData : Invalid header
    >BL [316 ms]:SplashScreen : GetLogoData : Logo info could not be retrieved!
    >BL [450 ms]:SplashScreen : GrafikInitShowSplashScreen : Start tPictogram task
    >BL [450 ms]:SplashScreen : GrafikInitShowSplashScreen : Load the Splashscreen with type 00021675
    614E45F0 uglCPDRVideoInit(picF:0, picS:0)
    614E45C0 ad9883Init -done: 0
    614E45F0 uglCPDRVideoConfigInit()
    614E10F2 cpdrVideoInSetSource DVD
    >BL [466 ms]:GrafikInitShowSplashScreen
    >BL [466 ms]:IL_UserRead : valid InfoLog in RAM found
    >BL [466 ms]:IL_UserRead : result = 00000000 bootmode = 0000001F
    >BL [466 ms]:WTIL_REC : NMBH_RecoveryNeeded = false
    ++>>> ST10 did not send boot-validity <<<++
    -> BL : 466 [ms] Check SystemReset-Reason
    >BL [466 ms]:try to launch OS-Image-Fast
    >BL [466 ms]:LaunchExisting 01: dwImgId 00000014 dwImageAddr 40000001
    ------- ImageHeader ----------------------------------------------
  6. #4
    Dec 2024
    Any updates?
    Jan 2020
    Czech rep.
    Look at the SWL history and use some of previous installed version. 5238 may not work everywhere.
