Results 1 to 3 of 3
    Nov 2011
    Default AUDI A4 2016 - ODIS - FAZ9484E problem
    AUDI A4 - 2016 - 8W model - need replace the broken dash (non virtual dash)
    initially the GATEWAY (19) have 1 DTC :
    1 Fault Found:
    6291457 - Control Module Blocked
    B2017 00 [00001001] - -
    [Immobilizer_Locked]
    but engine start, no problems
    17 - dash - has NO IMMO, no vin, so adapting is only a matter of "component protection" (and coding etc...)
    1) I replaced dash with a (same) used dash, online GEKO @ dealer level, but gives me error "FAZ9484E / Checksum-1 is incorrect"
    FAZ9484E is known as faulty part, so i buy a NEW DASH !
    2) new dash, online GEKO....SAME problem ("FAZ9484E / Checksum-1 is incorrect")
    3) i go to 19-gateway, did also component protection remove, but give me same problem IN this gateway !!
    so conclusion = the 2 dash (used and new) are oke, but gateway maybe is broke ?
    anyone had same problem, or solution ?
    how to "unblock" a gateway ?
    Thx for any feedback
    brend's Avatar
    Oct 2015
    Same where
    ODIS Common Error Codes
    FAZ2781E This accessory is locked, please replace it with another one.
    FAZ4990E This accessory is disabled, please replace it with another one.
    FAZ9484E FAZ9488E This accessory is damaged and cannot be adapted online.
    FAZ2946E The second-hand cluster/instrument does not work, please replace it with a new one.
    FAZ1224E There is a problem with the data of the cluster. Please replace it with a new one.
    FAZ1243E There is a problem with the Gateway. Please replace it with a new one.
    FAZ1531E The key is already bound to another vehicle.
    FAZ1532E Aftermarket spare key, and the key cannot be used.
    FAZ1552E The key has expired. New keys are valid for 90 days.
    FAZ9113S There is a problem with the operation. Please contact us to solve the problem.
    ERP4711E
    Account has no permissions. You won't have this error using our account.
    FAZ4160E Account has no permissions. You won't have this error using our account.
  3. The Following User Says Thank You to brend For This Useful Post:
    rafal (9th June, 2024)
    Sep 2011
    I also had the error ("FAZ9484E / Checksum-1 is incorrect") when programming a brand new speedometer online. No matter what I tried, no chance.
    You can easily program the speedometer with AVDI and adapt it to the car.
    RH850 programmer reads the data from the old one, puts it in the new one, the rest in the car. Programming the key, etc. Did it yesterday, works.
    Old Dash (analog):
    Adresse 17: Schalttafeleinsatz (J285) Labeldatei:| DRV\5G0-920-XXX-17.clb-SRI3
    Teilenummer SW: 3G0 920 741 B HW: 3G0 920 741 B
    Bauteil: KOMBI 204 8311
    New Dash (FULL TFT / Activ Info):
    Teilenummer SW: 3G0 920 791 D HW: 3G0 920 791 D
    Bauteil: KOMBI 404 4191
