Results 1 to 4 of 4
    Jun 2024
    Default 89170-02G60 2016 corolla s crash reset
    Hi guys, could someone help me with clearing the crash data for this 95M01. Tried online service and did not work, just waste of money.
    FranciscoAirbag's Avatar
    May 2021
    somewhere
    Hello, your file is clean, report back.
  3. The Following 2 Users Say Thank You to FranciscoAirbag For This Useful Post:
    green (10th June, 2024)
    Jun 2024
    Thanks Francisco will do
    Jun 2024
    Tested the file, it works perfect after doing one adjustment on the first line. Initially with the cleared file it was showing lost contact with srs module, I believe my original crash file got accidentaly edited on the first line showing 00, instead of being 55 aa 55 aa. Also gave many dtc codes for ABS fault, traccion off and srs malfuntion. Seems that if the first line of the programming is not right it wont determine the module, especially since this area contains the module information i.e (02G60) hence giving all the codes. Once i put the right values worked perfect, dash light off and passanger light functions as supposed to on/off depending if seat is occupied.
    Great job and much appreciated.
