Results 1 to 3 of 3
    Jun 2024
    Default Kess V2 - External exception EEFFACE
    My Kess V2-clone doesn't want to work.
    FW: 5.017 SW:2.80 Win 10 64bit
    I get the "EEFFACE"-error when selecting a vehicle (2006 Ford Focus ST) and when trying to close the program. To finally close it - I have to use Program Manager.
    The original micro-sd was bad - so I replaced it with a 2GB Medion I had lying around. The update via KSuite seemed to work.
    The red light is permanently on - therefore, I think it's not the firmware-update problem.
    Still, I get the error again and again.
    I tried various compatibility-modes, Win 7, Win 8, XP. None works.
    I installed, deleted and re-installed the driver. 10.009 - 10.011 - nope.
    I deleted the .Net 2005 programs - nothing.
    An exception in Windows-Antivirus for the whole folder is set.
    The folder is located directly on C:\ .
    I read a ton of stuff online - nothing helped so far. The sodering points look okay to me - but I'm no expert. The USB-cable can be bad, too - it sits quite losely in my Thinkpad.
    I'm willing to get a new cable - afterwards, I think sending it back is my best option.
    If anybody has an idea - it'd be really thankful.
    Jun 2024
    I think I solved it.
    The modified KSuite 2.23 (kess-2.23-safe.ISO) I found somewhere here on DK seems to work.
    After I finish my coffee - I give it a try.
  3. The Following User Says Thank You to W4rdialer For This Useful Post:
    fuzz1 (24th June, 2024)
    Dec 2024
    Hi, did you figure this out? I’m running into the exact same issue currently.
