Results 1 to 2 of 2
    Jan 2024
    Post help me fix the dtc code on ppd 1.2 2.0tdi 125kw 2006
    help me fix the dtc code, egr and dpf is already disabled in the past, the fault will probably be in the wrong turn off of the egr
    the car writes an unknown error code when I put the original file it says a problem on the egr
    Sep 2022
    Birmingham
    try this buddy
