Results 1 to 3 of 3
    May 2017
    Default Renault Trafic year 2003 AKL mech key code
    Hi to all!
    I need make key for Renault Trafic year 2003, i found this label in the car.
    Blade i thiNK is NE72, i try to cut with:
    N-P-P-M-P-R
    R-P-M-P-P-N
    But no succes.
    Someone have idea?
    Thanks in advance
    Dec 2010
    Nottingham
    it is direct cuts so that code NPPMPR would be what its suggesting though the R may be a P with a mark on it as not a clear r
    personally i would use NE72 lishi 2in1 , pick and decode in well under 2 mins to get correct code.
  3. The Following User Says Thank You to rapidlocksmiths For This Useful Post:
    ginodilegno10 (19th June, 2024)
    May 2017
    You are right, i try with P to R cut.
    If not work i will buy lishi NE72
