Hello guys,
Anyone with a nice Stage 1 for that car ?
Here is the read file with kess
Hello guys,
What are you saying, I don't get it. This the original file.
Edit: why wouldn't I be able to write the stage 1 file?
So what should I do, I've never had that problem. Only that I can't read some ECU and need ktag. But I can always write (and here I did read the file)
I should use K tag to write to file or I have to read it with ktag first? Is it OK to read with kess and write with ktag?
Thanks a lot.
That's bullshit, you can easily write with KESS. Be carefull only for partial and full read.... post your hw and sw number I probably can help you. From the file is only SW number readable: 504037
If I helped you, THX&REPUTATION will be nice. No PASS on my files, I just trust you.
Italian cars <3
Here's the ID... what do you think ?
I tested it. It cost less work.
The problem is not the save,
but the fact that BCM crashes.
Reading link k can does not work.
If you have a ktag, what's the problem with reading it?
Will my friend have EPROM BCM?
Maybe I can share it with you (+ keys because they will be lost)
Yes, other versions read well, but this one doesn't.
Successful life
