Has anyone got the english version of Dbox2 Flashing Assistant?
IFA V3 is in English
https://www.ssl-id.de/hallenberg.com...ent=downloads&
Although the writing is in German you have the multi language option during install.![]()
any step by step guide to flash nokia dbox2 from the scratch? coz I am newbie in this tech and my nokia dbox2 says "Waiting for Timing" all the time...
Hey driniking_eyez,
You need a serial cable and a cross over cable.
All the guides you need are in the downloads section:
Digital Kaos - Downloads - Guides
tid
Better still, try IFA 3.1 Portable, thanks to our good fiend Renwich. All in English- and the first IFA I've ever tried where you DON'T need a null-modem cable.
It's a standalone, too- will work from a USB Stick drive! Works great for me, even when AVG 8 is active.
Cheers- AL![]()
thanks all sorted thankyou for all your help![]()
I'm complete newbie here .... I'm trying to flash by dbox2 but. I tried to download the guide to flash but wouldn't let download .. do you guys know why ??
hi gizmo
thanks .... ya i've managed to download the guide ... but I still cant flash the box after going thru' the guide ...
This is what I'm trying to to ....
I've connected the dbox with rj45 (network cable) and connected one end of a null modem cable to dbox and the other end to a 'RS232 to USB' cable and connected the USB end of the 'RS232 to USB' to the PC and I've disabled all the firewalls.
I executed IFA 3.2.1 and it asked for the image which I selected (Commando_10cR_x2_20-12-2008_20h07.img) then selected the network card and on Step 3 where it asks whether you have a 'Null mobem cable' I clicked 'Yes' and for the port it only gives me com port 1 on the dropdown. so I selected that ... finally I clicked start button and all it says is 'waiting for Dbox to start' ... I've already started dbox but its not doing anything ... i've left for about 10 mins and its not doing anything ...
Ohh by the way I had an old image on the box already ... do I need to remove that Image from the box before I install the new image ??
hope you guys can help me ... I'm a complete newbie and I've never flashed a box before. so pls pls help me.
You have done everything correctly you are not too far away from flashing the new image.
once all the cables connected start IFA and do exactly what you said above then connect the power cable to Dbox and you will see that image flashing lines on your PC or Laptop monitor.
Good Luck.
If you like my post pleas click on the little button to say thank you.
Been looking for this - many thanks!
can someone help me to get my box up and running pls ... I've flashed my box but dont know where to go from there ... pls help me as i'm eagerly waiting for a response.
TIA
Wot image is on it now
Just push blue on remote
Select your location
Reboot and rescan .....................Paul
PAUL
thanks for your reply the Image I have is Commando 10 .. sorry I pushed the blue button but I couldn't find any place where I could set the location .. I'm in birmingham area how to set the location .... can u explain that in detail for me pls ... dont I need to copy any files after flashing ?
