Results 1 to 15 of 16
    Jul 2024
    Default Renault twingo mk2 new remote programming problem
    Did anyone have trouble with programming remote keys for twingo mk2. I tried on a couple but no luck. Car would start fine but remote just wont work. Tried keydiy, no luck. Tried couple of aftermarket keys, nothing. Some people are saying there is a special precoding procedure just for twingo but I cant find any information. Any help would be apricated.
    Dec 2010
    Nottingham
    on some you need to code the key multiple times till it codes in properly and remote works with some tools , ive never had an issue with them with avdi and truecode , but ive read some tools struggle , i also tend to use oem keys on them .
  3. The Following User Says Thank You to rapidlocksmiths For This Useful Post:
    stari1984 (15th July, 2024)
    Apr 2019
    Wrong key. Had same problem with Twingo using the usual Renault master/Trafic remote. Some Twingo (2010-2013) use a different key like this one: https://remkeys.com/product/twingo-2...nrk65-remkeys/
  5. The Following 3 Users Say Thank You to mjoesen For This Useful Post:
    albertros (23rd July, 2024), p1et (15th July, 2024), stari1984 (17th July, 2024)
  6. #4
    p1et's Avatar
    Oct 2013
    Quote Originally Posted by mjoesen View Post
    Yes, that is correct. Personally I just make correct precoding by Miraclone.
  7. The Following 2 Users Say Thank You to p1et For This Useful Post:
    rokibar (16th July, 2024), stari1984 (17th July, 2024)
  8. #5
    Jul 2024
    Finally I was able to do it. I used a Xhorse key (purple) and it works great. Programmed it with autel im608.
    Thanks to everyone that replied.
  9. #6
    p1et's Avatar
    Oct 2013
    Quote Originally Posted by stari1984 View Post
    Well, soon you will meet again with your customer.
  10. The Following User Says Thank You to p1et For This Useful Post:
    rapidlocksmiths (17th July, 2024)
  11. #7
    Dec 2010
    Nottingham
    Quote Originally Posted by p1et View Post
    agreed , be prepared to meet again
  12. #8
    fuzz1's Avatar
    Jul 2019
    What is the problem using those xhorse keys?
  13. #9
    lion0304's Avatar
    Oct 2014
    Quote Originally Posted by fuzz1 View Post
    Xhorse, KD all with electronic or firmware failure
  14. The Following User Says Thank You to lion0304 For This Useful Post:
    fuzz1 (18th July, 2024)
  15. #10
    Dec 2010
    Nottingham
    because the remote functions often fail in a short time , this affects all of the generated keys judging by the amount of them i get to change after their cheap service wont come back to them especially on renault and on fiat marelli keys
  16. The Following User Says Thank You to rapidlocksmiths For This Useful Post:
    fuzz1 (19th July, 2024)
  17. #11
    Dec 2021
    Had a twingo 08 akl last week tried all possible settings on keydiy &xhorse.. with every try ignition on and hold the unlock or the lock button for 40 -60 seconds .. no joy.
    Ordered this key from 3D and went back to the car yesterday still no joy 🥲 programmed the key 2-3 times with 508 and twice with avdi still no joy only starts the engine fob not working
    Any idea what the F is going on?
    https://3dgroupuk.com/product/view/RER20c
  18. #12
    Jul 2024
    Well to be honest as a car locksmith shop we mainly use keydiy and xhorse keys and we have done a lot of them. So far our experience is that they either work or they don't work at all. So far not even one customer has returned with a keydiy or xhorse key. Even the customer of the twingo didn't complain and says he wants another.
  19. #13
    Dec 2021
    Totally agree
    Personally I see it as xhorse wire/wireless less stable then the XM38 and the super remot(purple bag), and keydiy no issue at all what so ever.
    Can you share the pre settings you generated the key for the twingo?
  20. #14
    Jul 2024
    I used the purple xhorse key. Firstly I generated remote under Renault Twingo (there should be only one option for twingo mk2, make sure you done generate for mk3). After that I generated transponder for Clio III. Then just programmed with IM608.
  21. The Following User Says Thank You to stari1984 For This Useful Post:
    azikri locks (4th August, 2024)
  22. #15
    Just a thought. Are you using a new key with the same number of buttons as the missing one?
