hey everyone i have the gemini image and cccam installed and running on my dreambox. i am trying to find the CCcam.cfg in the var directory on flashfxp but it is not there? where can i get it from? help please!!!!!
CCcam.cfg file is normally found in the var/etc folder.
Depends if you loaded cccam full or bin.
All Done Cheers!!!
can anyone give me a little info on cccaminfophp and where i can get it from and the best one the only 1 i can get has a password any info would help thanks.
i have nabilosat v.08 would it be in theres
you need to download it from there server through the blue button via the addons on there image
dm800-s=1.1 m triax motorised dish=titanium twin lnb
DIGITAL KAOS BEST SITE ON THE NET
please use the thanks button if someone has helped
If you sure cccam is installed and starts up when box starts then can you not create the file and put your clines in it?
If it's starting up m8 it's got to be there
If you cannot find CCcam.cfg even after you have downloaded CCcam 2.14 from their server then there has to be something wrong. I would flash it with the Pli Jade 3 and download CCcam 2.14 from their server and use that as this always worked on my dm500.
