Results 1 to 3 of 3
    fuzz1's Avatar
    Jul 2019
    Default VW crash shut off active
    I have this fault code that will not clear on a VW polo 2020
    Crash shut off active b189cf0.
    Data bus obd interface
    There's no light on the dash but that fault says active
    Aug 2020
    I had problem with transit once, crash sensor tripped when wind took passenger door. The sensor was behind glovebox. pressed the top of it back down and all was good again. Maybe there is a similar sensor in the vw
    HaynesPro 2025 online + AC/ Delphi 2022.02a available, message for where to get them!
  3. The Following User Says Thank You to crouchinggerbil For This Useful Post:
    fuzz1 (2nd September, 2024)
    audiozonetech's Avatar
    Aug 2024
    Quote Originally Posted by fuzz1 View Post
    Hi friend, It's easy with VCDS (vagcom) or with an advanced scanner like Launch or Autel, here are the steps:
    1.- Enter to 19- GATEWAY
    2.- Select the option : "Basic settings"
    3.- Select the option in menu: "Reset of reversible crash shutt off"
    4.- Select "OK", "Do it" or "Adjust" (depends of scanner used) and wait for confirmation message: "Finished correctly"
    5.- Clear de fault codes and start the car.
    6.- Cycle the ignition and read fault codes
    7.- B189FC0 is cleared now.
  5. The Following 3 Users Say Thank You to audiozonetech For This Useful Post:
    dragon100 (2nd September, 2024), Fermejia (21st November, 2024), fuzz1 (2nd September, 2024)
