Results 1 to 15 of 17
    west midlands
    Default can op-com programme a replament ecu to vectra c
    hi guy i have a mate who has asked me if i can use my op-com to programme a replacment ecu to his 1.8 vectra c he has car pass's to both ecu and been told that the replacment ecu has been blanked from the doner car can i reprogramme the new ecu to his car with my op-com if so can somebody explane how to do it many thanks in advance.
    Quote Originally Posted by f1racingmad View Post
    YES OPCOM CAN DO THIS.IF THE ECU HAS BEEN RESET OF DONOR CAR ,SHOULD ONLY NEED PASS FOR THE CAR ITS GOING IN. YOU HAVE TO SELECT YOUR CAR IN OPCOM THEN GO INTO PROGRAMMING ON THE RIGHT HAND SIDE OF THE SCREEN ,THERE YOU WILL FIND OPTIONS TO PROGRAM THIS TO THE CAR. HOPE THIS HELPS
    DONT FORGET TO SAY THANKS
    west midlands
    i will give it a bash what the worse that can happen is says no
    west midlands
    just thinking do you know which 1 of the programming options i need to use and is just 1 or do i have programme a load of stuff
    obdmaster's Avatar
    Never never land
    Thumbs up
    You say replacement ecu has been reset? If so go here :
    http://opcomforum.yolasite.com/guides-and-info.php
    and use the one about diesel pump programming in there you will find how to program a psg16 pump on a vectra c, it will be same procedure for your ecu m8 .
    west midlands
    would i start the programming from reset the ecu and woukd need to use the doner cars pass key or the cars own pass key
    if the new ecu has been reset before taking offyou will just need security pass for the car its going into m8
    west midlands
    ok then will i need to programme any thing else or should it recode its self sorry new to this
    Croatia europe
    last few days I have similar situation on 3 opel cars..It Is important that new ecu is reseted...and you need pin code for youre car|for existing immob| you dont need pin from new ecu..
    start opcom //conect to immo /read erors/open special programing/ lower buton should be something like pairing or similar expresion...
    also with opcom you can/must change the VIN inside this /new/ ECU...
    ok now you can start the car..read all erors from engine ECU..of course there will be aditional work..exept donor and donate are apsolutly same ..same aircon..same abs..traction control...there is lot of diferents from car/to car...
    regards!
    west midlands
    all i have been told is that all the ecu numbers of the doner ecu match the ecu thats got to be changed
    Croatia europe
    that means you will make it for sure..still there is posibility that cars dont have SAME equipment..ex donor have manual aircon and youre car is climaautomatik...stuff like that..but you can solve it easy..read all what you can from old unit and folow the screen in opcom when you make adyustment on new ecu..simple procedure
    vanya86's Avatar
    Ljubljana
    Quote Originally Posted by obdmaster View Post
    I have opel astra G bertone 2003y. 2.2 DTI BOSCH vp44 pasg16 with 2 connectors. I have asked several people and without success. They say that hist engine is not possible to tune. i have option only to read ECU, not to write.
    Does anyone know anything about how is this possible.
  13. #13
    how i can make reser the old ecm to be use on anther car ?
  14. #14
    Quote Originally Posted by vanya86 View Post
    you can only read with CARPROG
  15. #15
    Top Poster + metsat's Avatar
    on world
    Quote Originally Posted by seed212 View Post
    best method of resetting for opel ecu's. You should use SPS(Service programming) in TECH2..
