Garmin Mobile PC 5.00.70g | 183.3 MB
The advanced technology used by GARMIN, allowed to develop GPS-receivers, which carry out fast and firm grip of satellites and continuously track your location with low power consumption. GARMIN GPS-receivers have high computing power, providing a continuous update, smooth scrolling maps and display your location in real time. After acquiring GPS-receiver from GARMIN, you will be able to extract from it the maximum of useful information through a unique combination of precision, quality and reliability inherent to all devices GARMIN.
Navigation software platform for the PC.
As part of the actual program itself, a separate folder with the Russification necessary Kigenyi and IMEI-converter, a small guide on how to unlock a FilesUnlock.zip
Installation:
1. Starting GarminMobilePC_50070.exe and set who have no problems with installing miss butter. step and look paragraph 3;
2. For those who (as in my case) is not installed on windows 7 with the error "not found a previous installation, install WinRAR and using it (right mouse button Click on the installation, choose to open with WinRAR) to unpack the contents of the installer into a separate folder, then simply klatsnut on MAIN.msi - installation starts;
3. After installation, it is desirable to establish a base map;
4. In order to earn Russian entry, change to Que.exe patched folder RUS_50070 (originally Russian entry is blocked)
5. For the Russification of the interface and voice set - to rewrite all of the same folder RUS_50070 two daddy Text and Voice in the folder with the installed program, then in the most for the Russian language;
6. To program has earned a third-party GPS receivers need unlock (use Kigenyi to generate activation code, which in effect put in the file sw.unl (see FilesUnlock.zip);
7. Using the same Kigenyi to unlock maps for FID / PID, put the activation code maps in files of the gmapsupp.unl, gmapsup2.unl etc.
Platform: PC
Language: English, Russian
License: Shareware (Cracked)
http://hotfile.com/dl/38532290/92dd4ae/GarminMobilePC.5.00.70g.part1.rar.html
http://hotfile.com/dl/38532310/35d0abb/GarminMobilePC.5.00.70g.part2.rar.html
