Results 1 to 5 of 5
    jamienatorr's Avatar
    May 2018
    Poland
    Default Volvo v50 1.6 EDC16C34 egr
    Hi, the previous owner removed the egr itself in this file. I read the ecu, I see that the sums are incorrect, but I don't have the original with this sw. Could someone correct this file for me so that the egr is properly disabled?
    Sep 2024
    Here is EGR OFF
    Dec 2022
    Here my friend check sum corrected.
    Did you read by obd kess v2?
  4. The Following User Says Thank You to antonis132 For This Useful Post:
    jamienatorr (Yesterday)
    May 2018
    Poland
    read by ktag
  6. #5
    br556hre's Avatar
    Mar 2010
    You have 2 scenarios here, if egr valve itself is working you want to close it trough hysteresis if it is broken or missing you will also need to delete few dtcs not to have engine light cmplaining about egr problem.
