Results 1 to 14 of 14
    Default 2004 peugeot 206 key problem ?
    bought a 2004 206 peugeot the key has messed up battery wnet flat so changed the battery now it will not open the central locking or turn the immobaliser of any ideas as how to reset this ?
    Could try to make a diagnostic to bsi or.turn off battery again for one or two hours.Reconnect it and see if all ok,windows too.
    Fallen's Avatar
    CENTRAL DOOR LOCK (1 BUTTON PLIP KEY)
    1. Ensure all doors are unlocked using the key.
    2. Press and hold plip key button until LED stops flashing.
    3. After releasing button, LED will light constantly.
    4. Press the Plip Button once, and LED will extinguish.
    5. Open the door and hold the Plip key near the Ignition switch, and press the plip
    but ton one time.
    6. Turn the ignition ON, and wait 10 seconds then turn ignition OFF.
    7. After 5 seconds, Plip should now operate.
    CENTRAL DOOR LOCK with DEADLOCKING (2 BUTTON PLIP KEY)
    2. Press and HOLD the large plip key button while the LED flashes continuously for 20 seconds. After 20
    seconds press the small deadlock button once while still holding the large button.
    3. The LED will stop flashing.
    4. Release the large button and the LED will light constantly.
    5. Press the large button one time, and the LED will go out.
    6. Open the door and hold the Plip key near the Ignition switch, and press the large plip button one time.
    7. Turn the ignition ON, and wait 10 seconds then turn ignition OFF.
    8. After 5 seconds, Plip should now operate.
    206 BSI
    1. Insert Ignition Key.
    2. Press the small Black button.
    3. Switch the Ignition ON
    4. Keep the lock button pressed for 10 seconds.
    5. Release lock button , switch ignition OFF and remove key.
    6. Close all doors and press the lock button 2 times.
    NOTE : If PLIPS still do not work, start the vehicle and then turn OFF. Open and close the door, and check PLIP again. This
    is also necessary after a new BSI system is fitted.
    Hope this helps
    Ashraf6119's Avatar
    UK
    Are you sure when you were changing Battery have you NOT Dropped the im*obilisers Chip from the Key.
    Just make sure if the im*obilisers Transponder Chip is there in the Key.
    Ash
    Member shakeelb's Avatar
    Feb 2011
    hi everyone
    i got a 206 bsi remote key .
    battery went flat .
    changed the battery.
    made the synchronisation as follows 1. Insert Ignition Key.
    but still not working
    i tried to remove the car battery and reconnect .still the same .
    can anyone help me please.
    would really appreciate.
    Jan 2012
    EU
    I do repairing, servicing remote key fobs for a few years successfully, but had the same problem before year ago on one peugeot 206, I think '02/'03. After PCB was cleaned, dryed, putted in new battery remote was tested with tester, worked ok, but synchronisation failed. Tried every "clever" advice but nothing. Applied reseting remote and the car by disconnecting battery 3 min., nothing. Added once again existing two keys with SBB, no faults, engine start ok, remote don't work.
    Never solved this problem!
    nabilyas8472's Avatar
    Oct 2011
    Morocco
    I think the only problem is synchronization
    leandroks's Avatar
    Brazil
    Sometime the processor get the eeprom dump corrupted, if so the information inside get lost and remote wont work. There is nothing u can do about..
    Feb 2011
    can anyone give me the eeprom reference .
    i think its motorola ....
    Mar 2011
    maroc
    hello
    it haS 95160 ST
    i allresdy have this problemm
    juste change the eeprom and reprograme your BSI whith new dump (vierge) and it will be ok
    Feb 2011
    hi
    anyone know where the motorola chip is sell plz?
    P&D's Avatar
    Quote Originally Posted by shakeelb View Post
    hi everyone
    battery went flat .
    Hi Mate slightly incorrect when i have re-sync this type of remote its all most the same......
    1. Insert Ignition Key with all the doors closed.
    3. Switch the Ignition ON don't press the the button till the ignition is on
    3. Press the small Black button.
    6. Get out of the car wait 5 seconds & try the remote.
    If its the same circuit board as the one above
    Hope this helps
  13. #13
    P&D's Avatar
    Quote Originally Posted by allforfun View Post
    Hi is it the 2 button flip key ????
    Or is the circuit board the same as the photo bellow ???
  14. #14
    Feb 2011
    hello
    yes that's it !
