Results 1 to 9 of 9
    DK Veteran trigital's Avatar
    Default VW ABS ECU 1K0 907 379 P J17
    As I understand this is a common fail for this ECU from ATE 1K0 614 117 H
    This ECu can not comunicate with car or diagnose.
    This is made in China:
    Controller
    *1D67B24A05*
    HM11/S0105
    1K0 907 379 P J17
    10.0970-0315.3
    00009496E5
    Is this a way for repair this comunication failure?
    Thanks!
    Hi m8,
    pleaese make picture from the opened ABS Module and post here. Propably i can help you to solve it.
    BR.
    RTVM
    Lixa
    hello
    what car that is installed to be able to help is important.
    Default ATE
    One of the so called ATE processors has a small hole in it!
    Is the one near the connector.
    This ABS is from a GolfV M2007 with only 15K km!
    Default Maybe VAG should look at this!
    This is a picture from ABS Controller from a GolfV with only 15k km of age!
    The chipset with hole was: 990-9393.1C
  6. The Following User Says Thank You to trigital For This Useful Post:
    laurentiudania (8th September, 2020)
    Default motorola
    Any info about this ATE 990-9393.1C ?
    Default 2nd Chip in this unit
    There is also another chip in this unit. A Motorola chip that needs to be replaced. Does any one know how to read it? SC550108MFU33. Maskset 1L93E
    Budapest,Hungary
    Default Vw golf+ ABS coding
    I need help Vw golf 6 + 2011' Abs coding
    1K0 907 379 BJ--ESP MK60EC1 H31 0121
    MOTOR :CAXA
    THANK YOU
    CRASHMAN
  10. #9
    Aug 2011
    Hi, I have same problem with ford fiesta abs module .... I solve it with one from Car dismantlers ... but now I find http://ecu24.com/en/integrated-circu...bs-driver.html
    I know it is an old thread but ... I don't find any other thread talking about this problem ... so I write their
    regards, Pipina
  11. The Following 2 Users Say Thank You to pipina For This Useful Post:
    geocity (15th October, 2021), laurentiudania (8th September, 2020)
