    Jan 2017
    Default Ford Transit D70F3525
    I have been trying to sort this out for a while, usually can figure it out, this has me stumped. It is from a 2018 Ford Transit, I Can see where the mileage is stored, just can't figure out the checksum. Seems to be in multiple locations starting at 7110, the km's at present is 268163 km. Seems to be X1000 which is 268163967 = 0F FB DB 7F, reversed at address 7110, 7F DB FB 0F and repeated 3 times then the CS, but the checksum is 01 3d. I have tried every calculator I know but it doesn't make sense. Can someone enlighten me please.
    Sep 2014
    how mileage you need
    Jan 2017
    They want 181548 km
    Jul 2014
    hi, here 181548, report
    Cheers
  5. The Following User Says Thank You to auto80 For This Useful Post:
    Scoopr1 (7th January, 2025)
    Jan 2017
    Thanks for that. Live data looks good with a scan tool bench test, will send back to customer to try in vehicle. How do you calculate the CS or do you have some software that does it for you.
    Jun 2017
    Hola, co que programador leiste
