Results 1 to 14 of 14
    Jan 2025
    Default me7.1.1 95160 Immo off Help
    Hi guys,
    I'm quite new to this but I have been researching for the past couple days trying to learn how to remove the immo from my ecu.
    The details of the ecu are-
    pn: 022906032 HJ
    eeprom type: 95160 ST
    me7.1.1
    removed from a 3.2 audi tt 2006
    I got myself a eeprom reader and ive removed the 95160 chip from the ecu. now ive eddited the file and flashed it to the eeprom (95160) chip. soldered it back to the board and given it a test. it connected to vcds and then stopped connecting so not sure if thats got something to do with the eeprom. Also the car still doesnt start (will start with another immo off ecu).
    anyway here are the files with immo on and off please can you check if i have done it correctly
    Some people are saying i still have to flash another part of the ecu. Can you tell me the full process of removing the immo from the ECU please as im really struggling now.
    Hayssam1's Avatar
    Germany
    Please Press Thanks Button and Reput if i helped !
    Apr 2023
    here your file off
    Jan 2025
    Quote Originally Posted by ylie86 View Post
    here your file off
    no file attached
    Jan 2025
    Quote Originally Posted by Hayssam1 View Post
    the file size of that bin is 1024 bytes, but the one i got off my eeprom is 2048. would that be a issue ?
    gwiazdamb's Avatar
    Aug 2022
    PL EU
    Quote Originally Posted by johnjones1234 View Post
    no file attached
    The file is not needed
    You did the work yourself, write it down and you'll see
    PLEASE PRESS THE " THANKS " BUTTON
    Jan 2025
    Quote Originally Posted by gwiazdamb View Post
    did you check my immo off file, is it ok ?
    I write this to my eeprom but car not starting so i think maybe not correct ?
    gwiazdamb's Avatar
    Aug 2022
    PL EU
    There must always be communication
    If you lost communication after writing the eeprom, you made a mistake somewhere, maybe soldering
    Jan 2025
    soldering is all good, Does the ST10F275 microcontroller need to be patched ?
    gwiazdamb's Avatar
    Aug 2022
    PL EU
    No
    Communication is ?
    Jan 2025
    when i plug it in, it will communicate once but then it wont which is why i think something is wrong. did you check the immo file i flashed to the eeprom ?
    gwiazdamb's Avatar
    Aug 2022
    PL EU
    Have you read post #6?
    Go back to the original and do some diagnostics
    You have to have communication
    Immo fault, car starts and turns off after 1-2 seconds
  13. #13
    Jan 2025
    i flashed the eeprom with the original file and i can connect to ecu fine with vcds . the engine will start but then cut off after a few seconds.
  14. #14
    kiszka's Avatar
    save this file and I think it should be ok
    pass is on PM https://mega.nz/file/dzQTUBQZ
    Reality of life :
    1:Never argue with an idiot, he will drag you down to his level and beat you with experience
    2:It’s hard to argue with a genius. It’s impossible to argue with an idiot
    3:Jealousy is a sign of inferiority
    4:Everyone lies
    How much rubbish you leave behind, so much rubbish someone will have to read, or maybe you yourself
    If you like to read garbage, don't slow down, just speed up
