Hello guys,
I have a Nexiq USB Link interface , but i have only Deutsch cable(with 9 pins).
Does anyone have another cables( OBD..etc),and could help me with pinout diagram?
Anticipated thanks!!![]()
Hello guys,
Hope this help.
dupisa (21st October, 2014), helboy1985 (3rd August, 2014), hieu1987 (19th December, 2019), hrobertdm (27th November, 2013)
Thanks for your help,but is not what i need , does anybody have some real answer tomy problem?
[Cita = cccosminus; 602593 Gracias] Por tu Ayuda, Pero No Es Lo Que necesito, ?ALGUIEN Tiene Alguna Respuesta real de las Naciones UnidasProblema mi? [/ Quote]
"Only death is the end of hope, everything else is just despair"
Thanks again ,but still don t resolve my problem...my conector on interface got 26 pins, and from there i don t know where ,and how wires goes to OBD conector...and to other conectors(for Caterpilar, Volvo..etc).
Does anybody have this kind of Nexiq interface and cables??
[Quote = cccosminus; 603964] Gracias de nuevo, pero don t resolver mi problema ... mi conector en la interfaz tiene 26 pines, y de ah? yo no s? d?nde, y c?mo va a cables DAB conector ... y otros conectores (para Caterpilar, Volvo .. etc).
?Alguien tiene este tipo de interfaz de Nexiq y cables?
[/ Quote]
is a paralel port? if is it this one 25 pin you need
Here what i have:
and is with 26 pins.
[Quote = cccosminus; 605403] Aqu? lo que tengo:
y es con 26 pines. [/ quote]
why dont samples the the entry of the interface?
i Know what do you mean i have the same trouble
i order conectors
OBD II 448013
OBD II 444009 (some Ford and GM)
i hope my connector arrive on a week
and then i can help you![]()
cccosminus
In the past they have always been DB15 connectors. Looks like they changed the design. If you have an ohmmeter can you tell us the pinouts on your connnector. I can help you make an adapter for 6pin trucks. I think the OBD II 448013 connector is also DB15 so thats not going to help you if the connector on the interface is 26 pin.
rp1210a ,
Sorry for delay but tomorow i ll try to put what i have, hoping that we will do all that types of cables.
Thanks everyone involved !
tengo el nexiq usb link y tengo los cables para volvo rectangular de 8 pines el cable y de 6 y 9 y tambien el obd heavy duty no se de cual especificamente les pueda servir para intentar subir el diagrama
who have the cummins inline 25 pinout cables diagram?
SOFT FOR ANDROS BENCH 6330 HELP PLZ.
I don't have a diagram but I do have the cable. I'll try to do a pinout of it tomorrow
