Page 3 of 3 FirstFirst 123
Results 31 to 39 of 39
  1. #31
    Nov 2008
    Quote Originally Posted by MetMan View Post
    running out of ideas here m8...i ain't dun this but u could change network adapter setting link speed / duplex mode to 10Mbps / half duplex this is in line with the box
    its end m8 i cant do anything about it
    do u know anthing about that window Leo XP v.2 Core Innovation
  2. #32
    Jun 2008
    Quote Originally Posted by danna View Post
    no.....where r u?
  3. #33
    Nov 2008
    buckinghamshier
  4. #34
    Jun 2008
    buckinghamshier
    bit far for me to try then.....
    if u have a null modem the u could try hyperterminal method or try this.....rodboys method
    Turn off windows firewall
    Disable wireless network connection
    Rename image file mtd3.img and store it in C:\
    set Local Area Connection network IP to 192.168.0.201
    ( IFA automatically sets dbox IP to 192.168.0.202 )
    configure Local Area Connection link speed / duplex mode to 10Mbps / half duplex
    open IFA
    select image for flashing ( mtd3.img from C:\ )
    select network device ( there should only be one available )
    switch dbox on
    press start
    a dialogue box pops up
    switch dbox off
    click ok
    switch box on
    flashing should begin
    progress is indicated on LCD ( IFA image on TV screen )
    Fertig and smiley faces on LCD means success
    disconnect network
    off then on at the mains
    The flash process takes three or four minutes.
    Note that it might not kick in first time, but this method will flash your box and / or recover from a kein system / loading kernal error.
  5. #35
    Nov 2008
    can i send it
  6. #36
    Jun 2008
    can i send it
    if u want....try method above first if not pm me
  7. #37
    Nov 2008
    ok i well m8
  8. #38
    Nov 2008
    i have did it thank u so so so much for ur help m8 s all back and working fine thanks again
  9. #39
    Jun 2008
    open IFA
    switch dbox on
    press start
    switch dbox off
    click ok
    switch box on
    disconnect network
    Thanks for this guide, I have given it a try, I can't get it to work but it has gotten me further than what I had been doing previously.
    Could you assist me a bit further here as I don't think that I am to far away from sorting this out.
    I am unsure if I have a straight through or crossover cable.
    But when I run IFA it shows up on the box lcd and also my tv so I take it it is the right cable but the box just hangs with the message on the box lcd saying dbox2 flashing assistent but this never changes to indicate any progress. I have left this for 15 minutes but no change.
    When looking at the boot manager screen during the flash process i have this message
    ***Adapter Desc: Broadcom 440x 10/100 Integrated Controller (via IpHlpApi #0)
    ***MAC address: xxxxxxxxxxx Local IP: 192.168.0.201
    ***BootP server started... Port 67
    ***TFTP server started... Port 69
    BootP> Request from 00:50:9C:39:9F:35 (assuming that this is DBox).
    BootP> Created dynamic ARP entry for DBoxIP 192.168.0.202 with MAC 00:50:9C:39:9F:35
    BootP> Answer sent!
    TFTP> Started TFTP-Transfer for "C:\ppcboot66443\ppcboot_nullmodem"...
    TFTP> Transfer finished, sent 394 blocks
    BootP> Answer sent!
    TFTP> Non-BootP TFTP-transfer requested "C\tftpboot\logo-lcd"
    TFTP> Started TFTP-Transfer for "C:\ppcboot66443\logo-lcd"...
    TFTP> Transfer finished, sent 16 blocks
    BootP> Answer sent!
    TFTP> Non-BootP TFTP-transfer requested "C\tftpboot\logo-fb"
    TFTP> Started TFTP-Transfer for "C:\ppcboot66443\logo-fb"...
    TFTP> Transfer finished, sent 352 blocks
    but at the bottom of boot manager it says Pinging dbox 2 failed.
    here is the log from IFA
    ?debug: DDF: Calibrating delay loop... debug: DDF: 66.76 BogoMIPS
    debug: BMon V1.2 mID 03
    debug: feID 00 enxID 03
    debug: fpID 52 dsID Hallenberg.com
    debug: HWrev 61 FPrev 0.23
    debug: B/Ex/Fl(MB) 32/00/08
    WATCHDOG reset enabled
    dbox2:root> debug:
    BOOTP/TFTP bootstrap loader (v0.3)
    debug:
    debug: Transmitting BOOTP request via broadcast
    debug: Got BOOTP reply from Server IP 192.168.0.201, My IP 192.168.0.202
    debug: Sending TFTP-request for file C/ppcboot66443/ppcboot_nullmodem
    debug: Got Block #0050
    debug: Got Block #0100
    debug: Got Block #0150
    debug: Got Block #0200
    debug: Got Block #0250
    debug: Got Block #0300
    debug: Got Block #0350
    will verify ELF image, start= 0x800000, size= 201596
    verify sig: 262
    boot net: boot file has no valid signature
    Branching to 0x40000
    ppcboot 0.6.4 (Apr 11 2002 - 16:10:44)
    Initializing...
    CPU: PPC823ZTnnB2 at 66 MHz: 2 kB I-Cache 1 kB D-Cache
    Board: ### No HW ID - assuming TQM8xxL
    DRAM: (faked) 32 MB
    Ethernet: 00-50-9c-39-9f-35
    FLASH: 8 MB
    LCD driver (KS0713) initialized
    BOOTP broadcast 1
    TFTP from server 192.168.0.201; our IP address is 192.168.0.202
    Filename 'C/tftpboot/logo-lcd'.
    Load address: 0x130000
    Loading: *##
    done
    LCD logo at: 0x130000 (0x1F9FFC0 bytes)
    BOOTP broadcast 1
    Filename 'C/tftpboot/logo-fb'.
    Load address: 0x120000
    Loading: *####################################
    done
    FB logo at: 0x0 (0x1FC0000 bytes)
    AVIA Frambuffer
    Input: serial
    Output: serial
    Select (1-3), other keys to stop autoboot: 0
    'bootd' recursion detected
    dbox2-ppcboot>
    ------ Systeminformations ------
    Selected networkdevice: Broadcom 440x 10/100 Integrated Controller (0)
    IP-address of the networkdevice: 192.168.0.201
    IP-address which the dbox gets: 192.168.0.202
    Operatingsystem: Microsoft Windows XP Home Edition Service Pack 2 (Build 2600)
    ------ Powered by Hallenberg.com ------
    Also I am unsure if the sagem is a 1 or 2 image, would the flash still complete it I am using the wrong image?
    Thanks very much
