Results 1 to 15 of 19
    Land of Rocks
    Default A8 2005 turbocharger regulator
    I have changed the turbocharger regulator J724 for Audi A8 2005 engine 3.0TDI ASB. Now I have DTC code 13128.
    How to adapt it with VagCom ?
    I didn't try it by myself, but have following info:
    - 01 engine
    - 04 basic settings
    - channel 033
    - On
    May 2009
    Quote Originally Posted by Alex789 View Post
    - 01 engine
    - 04 basic settings
    - channel 033
    - On
    not work,
    on channel 033 brake pedal...trottle....I'm confused about it,
    i have same problem ..
    013128 - Control Circuit for Controller for Turbocharger 1 (J724)...adapatation..
    any help ??
    thanks in adavance
    tomtom0785's Avatar
    Austria
    what about if you're trying to save in channel 00 of adaption?? usual this function clears all the learnt values
    or even you try login26262 and look for adaption channels - maybe works for ASB Engine - but not sure
    enjoy and have Fun
    Tom
    Apr 2009
    19804/P3348/013128 - Ross-Tech Wiki
    check wires!
    anyone with elsa installed?
    Ashraf6119's Avatar
    UK
    Basically this fault code is pointing towards the Component, or Electrical Wiring fault.
    Have a look in here for more info.
    Hope this helps.
    Ash
    Thanks Ash
    Oh yes if my post was helpful than Please don't forget to press the Magic word Thanks
    May 2009
    Quote Originally Posted by tomtom0785 View Post
    thanks for reply,
    login 26262 not work , is not accepted.
    tried to make the save with 00 channel, and I tried again base setting channel 033.
    I always error (J724): P3348 - 005 - No or Incorrect Basic Setting / Adaptation
    Car is Audi a4 b7 3.0TDI motor ASB.
    did you replace only the regulator,or the turbo with regulator?
    May 2009
    I just replaced the regulator.
    to adapt the new regulator to the turbo you need a tester from omnitec and a specific software , there are 2 versions, one for each turbo model ! adaptation is something similar to basic setting, but you can do only with that tool ! better go to Audi dealer for this !
    Apr 2009
    @gcesare21
    As I see car is manufactured 2005, Elsa Audi from 2006 has all procedures inside, not like these new ones that point you to VAS , i think it comes on 5 or 6 cd's, I got them somewhere, will try to find them and install.
    @catalin
    Whats the model or name of that omnitec tester?
    I do not remember what's the name . Better write a mail to omnitec, or check at audi dealer what tester they use for this job .
  13. #13
    Apr 2009
    I've checked this old elsa I got, its 2.5 version, all vag cars untill 2003, so its too old....I also have 3.5 version installed and there's no procedure inside, are you sure you have to adapt that J724 device? Because procedure for replacement of that specific part is simple, you replace it with turbo charger....they don't even say that you have to do something else...
  14. #14
    May 2009
    I am sure that the valve has to adapt, because I changed one more time
    the dealer has done the adaptation
  15. #15
    at least you have the car repaired..this is important !
