Results 1 to 15 of 22
    Default This is how i disable Immo on Toyota Rav4 01/03
    Hey hope this help anyone to disable immo in a 01/03 Toyota Rav4 2wd you just have to cut the brown wire thats its located on the E8 conector pin #22 and that its Immo disable i have tested severals time in this model dont know if work on other Toyotas.
    by the way doing this dont get u any Immo DTC
  2. The Following 2 Users Say Thank You to kamikazedr For This Useful Post:
    CHIKO (5th November, 2018), cristinuz (13th September, 2024)
  3. #2
    I guess that cutting the brown wire you mentioned is the same as removing the jumper in the engine compartment fuse box, which is circled in red in the diagram below.
    Dec 2010
    Hi, i have a Toyota RAV4 2001 ECU #1AZ-FE, engine crank but won't runI check with my scan tool and I get IMMO ACTIVATED. But I check and muy car don't have antenna and the key without transponder.
    This procedure works for my TOYOTA?
    Cesar
    DK Veteran elecautocr's Avatar
    Quote Originally Posted by Cexar View Post
    Cesar
    Yes, it work
    Dec 2010
    Thanks. I tried this method, but doesn't work on car.
    Anyone have another solution?
    Oct 2010
    Hi!
    You need desolder and program eeprom 25080 from ECU.
    Try this dump (dump of new ecu - for auto key learning) with any Toyota key 4c.
    Good luck!
  8. The Following 10 Users Say Thank You to Zohar For This Useful Post:
    agudelui (4th April, 2015), cristinuz (13th September, 2024), datapage (7th May, 2019), Kalectro (9th October, 2024), lanefi (23rd June, 2019), magdyman (19th October, 2024), miloudmess (28th November, 2021), seftiba (15th July, 2015), Xhamlliku (19th November, 2019)
  9. #7
    Dec 2010
    The dump you sent me works!!
    Thank you very much Zohar.
  10. #8
    Jan 2011
    rep of congo,p/n
    hi friend,you may have a short circuit in your engine wiring, because of over heating,wires are touching together especially the coils wire,i mean the one on the top gasket,
    you should open the wiring of each coil and check them well then seperate them. taht should be the only thing that cease your engine to run,trust me
  11. #9
    Quote Originally Posted by Zohar View Post
    Hi!
    Good luck!
    Will this work for 1998 rav4 with 4c key and separate immo box?
  12. #10
    Nov 2010
    kaduna
    Hi PLEASE I need pin code for this 406 VF38BR6F281454252
    THANKS IN ADVANC
  13. #11
    umoussa's Avatar
    Universe
    Quote Originally Posted by ibrahimm View Post
    THANKS IN ADVANC
    Are you looking for a BAN my friend?
    This is not the right place to ask for this PIN
    ECU Commander Studio?
    Hand in Hand to Protect our Efforts - Stop Hunting Our Work
    >>>>>EBAY SELLERS<<<<<
    I'm not Sharing Passwords!
    Do not argue with an idiot. He will drag you down to his level and beat you with experience
  14. #12
    jebo's Avatar
    DURIAN CITY
    i have a no start 2001 rav4 without immo box and key has no transponder. ecu89661-42761.
    x431 says B2796 No communication in immobiliser system.
    will kamikazedr post work for this ecu?
  15. #13
    In engine fuse box there is one fuse location that does not have a name, remove this fuse and try.
  16. The Following User Says Thank You to shitad For This Useful Post:
    zigzag2588 (23rd April, 2013)
  17. #14
    jebo's Avatar
    DURIAN CITY
    already tried kamikazedr's post and it worked for my RAV4
    thanks to all
  18. The Following 2 Users Say Thank You to jebo For This Useful Post:
    datapage (7th May, 2019), zigzag2588 (23rd April, 2013)
  19. #15
    jebo's Avatar
    DURIAN CITY
    Quote Originally Posted by shitad View Post
    yes shitad, i found it. thanks!!!
