Here is tms370 dump from vw transporter im*o box, 6h0 953 257, siemens 5wk4 774.
im*o reader says code is 0
Am i missing something?
yes
the dump
ECU Commander Studio?
Hand in Hand to Protect our Efforts - Stop Hunting Our Work
>>>>>EBAY SELLERS<<<<<
I'm not Sharing Passwords!
Do not argue with an idiot. He will drag you down to his level and beat you with experience
hi your pin code is 01529...
Pin is accepted, thanks.
BUT I have a problem key will not code in. Customer got new key cut from vw, which came with transponder inside, i coded it using mvp worked then lost it, tried coding it using vagcom the same tried coding it using vag commander the same. We have an old box and key off same model vehicle so going to put dump on that box to try as anyone got any other ideas
Much thanks in advance as always
P.s this has come about from guy losing his key
Whith a new transponder, tp14 for vw
Lupu sandu the man, helped me to make key using GAMBIT, then i put dump back onto tms370 as i lost all keys trying to program in new transponder. Van is now a runner. BIG thanks to lupu sandu
