Results 1 to 15 of 15
    smirnoff_rules's Avatar
    Mar 2008
    birmingham
    Default MITSUBISHI L200 2.5 diesel 2003 codeS
    l have a shitty l200 towed in last night .. starts and cuts out , but if you leave the starter on few a seconds will tick over but will not rev but smokes bad? and the rev counters not working
    codes are
    12 boost sensor
    21 ne sensor main
    46 inj adv volts
    41 thort valve sol 1
    49 over boost
    52 vgt cont
    51 egr poss sensor
    dont no wot the rac did to it last night so cleared codes and now
    just have these
    12 boost sensor
    21 ne sensor (main)
    changed the twin sensors solenoids on these before but never had one this bad
    any ideas
    west midlands
    i'd say it's a fueling problem if not revving & smoking. what colour is the smoke?
    Mar 2008
    birmingham
    Quote Originally Posted by dafdiagnos View Post
    just black diesel smoke , if u leave the key on it revs high for a few seconds then dies
    west midlands
    will it run if you remove intercooler hose to inlet manifold - poss air starvation throwing air/fuel mixture out?
    Mar 2008
    birmingham
    tried that and blockin egr off still the same .. cant understand why the rev counter is not workin
    west midlands
    just out of interest, it hasn't been filled with petrol has it???
    Meat-Head's Avatar
    Just for a small amount of time required to check.
    Passenger side foot well, remove ecu, open look for dry joints
    If it has a 'tuning box' daisy chained to ecu remove it (stick it on ebay)
    You are lucky you have managed to get one to code read.
    THINK but might be getting confused with trooper
    when you do the cluch, you have a bit of metal 'left over' holds the loom away from the (THINK) bell end housing.
    Mar 2008
    birmingham
    l'll get u have a look at it tomorrow . bring your overalls
    cjawahir's Avatar
    T&T
    ne sensor = cam sensor
    boost sensor -- check for 5volts and ground .
    if the Ne SENSOR is bad or wiring the tach will not work .
    cj
    Mar 2008
    birmingham
    Quote Originally Posted by cjawahir View Post
    cj
    cant see a cam sensor on this model .. could ne sensor be a crank sensor ?
    cjawahir's Avatar
    T&T
    if you dont see any cam sensor , check the crank sensor.
    what engine does it carry ?
    cj
    Mar 2008
    birmingham
    2.5 td 4x4 .. think the sensors behind the cambelt covers
  13. #13
    Mar 2008
    birmingham
    just stripped the front off and the crank pully has come loose and knacked the sensor and the crack ... thats going to cost him ..
    cheers lads got there in the end
  14. #14
    neare the entercooler ther is a sensor like map sensor in petrol en. yu have to clean it and aull the vacome paeps inclodeng the matalls paeps mybe the manifold too
    pm to my if its helpe rega.
  15. #15
    cjawahir's Avatar
    T&T
    Quote Originally Posted by smirnoff_rules View Post
    good job , now if you had a pico scope you would have solve this easy , but you got there in the end .
    cj
