Results 1 to 8 of 8
    Default blaupunkt car stereo blocked
    Hi I have just had my car in to garage and the stereo was asking for a code, bec i put wrong code in the stereo says wait and will not let me put in another code.
    FIAT PUNTO
    BP937227226645
    There is a code on the back of 0875 which i presume is the right code but i cannot try this until i reset stereo. is there anyway to do this???
    Any help much appreciated i cant take any more silence in my car
    DK Veteran deffc0n's Avatar
    UK/POLAND
    Code is wrong
    Try this 4635
    joubliss's Avatar
    Far away
    Quote Originally Posted by catliz View Post
    FIAT PUNTO
    BP937227226645
    ur code........0891........8891
    M1DJF's Avatar
    West Yorkshire
    leave the radio on for a couple of hours and it will let you enter the code again unless its totally locked if that is the case you can upload dump(read the eprom) here and I will reset it for you.
    FIAT PUNTO
    BP937227226645
    Fradebo's Avatar
    belgium
    Smile
    4635 is correct.
    Leave the set and contact on for at least half an hour. It could take an hour. You can always use a separate battery or power supply
    Dont switch the set off or you have to start the procedure over again
    greetz Fradebo
    radio has been on for a week granted maybe only half hour a time as turn off when i get out of car is this not long enough?? can you not reset.
    Dont want to try all these codes as wil block again - 0875 is on back of radio will that not be the code??
    ok will leave on as long as i can and hope it resets then put in 4635 - thankyou for your help - fingers crossed
    UK/POLAND
    Yes code is OK
