Does anyone have access to the rover database. I need to obtain my EKA code, as my immobilsers playing up again! Immobilser seems to not be getting full power to it and is not disarming fully. Batterys fine though.
I also require this, any ideas?
i think even the ex dealers have to obtain the eka via e mail .but if you have the log book go to the ex dealer they can get the code and email or text you the cars eka, radio ,and key no .it costs me about 12 quid ..hope this helps
These codes can be read using a t300 from your vehicle diagnostic port they can also be changed so getting it from a database not a good idea. Check boot wiring if you have a 200 or 25 as when opening and closing boot wires short out also test remote on a rf tester . Rover remotes are prone to failure i
where is the cheapest place to get a T300?
ta
i got mines from china . and it cannot do rover eka codes ?
I have a t300 anda super mvp, both where bought from ecutool.com. you don't get the rover lead included . I got mine from t300cables.com. think the guy was called terry. The difference between the two machines is build quality being the super mvp far better as both run same software. If your using it for business get the super mvp
Testbook & T4 can read kac codes,most new MGTF dealers have them,few of the old Rover dealers still have them.
can you send me a link for t300cables.com.? i cannot find it ? thanks ...shuggy
Your right web site has vanished will try and
find it for you
good man above and beyond the call of duty ..cheers mate
Tried to find it but its gone , rover lead try phoning advanced diagnostics and see if poss to buy one. as the t300 is a copy of there ad100, sorry cant be more help
no problem . but if its not too much bother ...can you give me a pin out of your one then maybe i can make one ...?
should be easy enough to find the pin out with a multimeter on ohms setting with the buzzer ...? if you dont mind ?
If get chance will sort that tomorrow, remind me if I don't pal
