Hi guys, I have bought a Blaupunkt radio and missing the code.
May anyone help me pls?
881 BP030566175452
7612300350
881 BP030566175452
7612300350
Your code is 8891,
Okay sounds a bit confident saying your code is..., but it's only because I've answered a previous code requester for the same radio - and it has been confirmed correct using the same algorithm..
If it's not the code then your radio has been re-coded at some point.
best o'luck
[remember thanks button, if post useful]
Read dump and attach it here.
What should i read? May u send me the link pls.
Shinigami,
This is a fairly newish radio, can I ask if you have had it since new?
If you have had it since new, then knowing the history, we can rule out it ever being re-coded.
BP030566175452
7612300350
BP0305 and 7612300350 ==>>> there are no mistakes?
I have bought a car and the radio was there, then I want to connect with them trough bluetooth but it requires a code. I dont have the code.
8891 IS CORRECT GREETZ FRADEBO
kappa1 (15th September, 2015)
yeah I know but now I need the bluetooth connection code...
How can I found that one out
Bluetooth connection code should be recorded in the user manual to radio.
Are you sure your radio has bluetooth capability?
I've checked out two manuals for TravelPilot Rome NAV55E & NAV56E, none of which have bluetooth. They do have the facility to mute the radio should a car phone kit be installed.
Is there any symbols on the radio suggesting bluetooth capability?
