Page 4 of 4 FirstFirst 1234
Results 46 to 56 of 56
  1. #46
    Apr 2012
    doesnt work....crap!
  2. #47
    smirnoff_rules's Avatar
    Mar 2008
    birmingham
    new loader 2.12 here
  3. #48
    Jul 2012
    Default AVG showing loader as Virus
    AVG showing loader as Virus..
    What to do??
    how to use the loader??
  4. #49
    Jul 2012
    Default Thank You
    Quote Originally Posted by bossa View Post
    yes no probs here is a screenshot plus a tut complete with step by step images tut in pdf & microsoft office word formats. which ever is best for you. hope this helps.
    New to the site. Just quoting so I can have a look at the screenshots
  5. #50
    Jul 2012
    Default Problem at command prompt
    Bossa's Guide to Activate windows 7 with not genuine software message in corner.
    First of all open Command Prompt which is in Start Menu , All Programs , Accessories ... but you must run as administrator.
    Then simply type in this command:
    slmgr -rearm
    Within a few seconds you?ll normally see this dialog show up, saying that the command has completed successfully, at which point you?ll want to reboot.
    Now don't panic you will still get the not genuine message at start up but it shouldn't be in the corner
    of your desktop anymore.
    So Checking the system properties again shows that you now have so many days left to activate.
    Now run the Windows 7 Loader by right clicking and run as administrator (here is link to Loader) Windows 7 Loader.rar
    Then just leave the loader on Default mode and click install... Now once you click install it will disappear don't worry it will take a minute or 2 then tell you to reboot.
    Also if you wish you can tick the Advanced options and select your pc's make for serial and certificate's but it's not a necessity.
    Now once you get the message telling you to Restart your computer simply click ok and let the system reboot.
    And your all done your system should be fully Activated.
    And able to pass validation on the microsoft site at Genuine Microsoft Software
    Hope all this Helps you Good Luck !!
    Tut by Bossa.
    OK, when I open the command prompt as administrator and type slmgr -rearm I get the error message " 'slmgr' is not recogmized as an internal or external command, operable program or batch file. "
    What am I doing wrong here?
  6. #51
    DK Veteran Hoppy01's Avatar
    May 2011
    Scottyland
    Quote Originally Posted by sahilkh View Post
    What to do??
    Its a false positive mate, by the nature of what it does most AV's recognize it as a hack tool in the signature description..
    Its actually a simple program created by a smart guy, it loads before Windows and acts as an emulator that tricks Windows into thinking its legit.
    Good AV,s list it as a minor threat but AVG is well known for going into pop up overdrive at the wrong things and then falling over and dying when it misses certain trojans listed as severe.
    A would disable AVG and then run the loader..
    "Windows - A thirty-two bit extension and GUI shell to a sixteen bit patch to an eight bit operating system originally coded for a four bit microprocessor and sold by a two-bit company that can't stand one bit of competition."
  7. #52
    Member zorba anton's Avatar
    Buffalo NY USA
    Default Make Windows 7 Genuine - Daz Loader
    *Find and 'Uninstall' KB971033 (don't 'delete' you must 'uninstall it)
    *Uninstall any and all 'Loaders'
    *Start 'Windows Update'
    *'Change Settings'
    *Uncheck 'Recommended Updates' (you'll need only important updates)
    *Reboot
    (You should not get 'Windows is not Genuine' warning.
    If you do, then check that KB971033 is NOT installed.)
    *Start Windows Update
    *Uncheck KB971033
    *Hide KB971033 (it will not show as an update again)
    *Install all important updates
    *Reboot
    You have 30 Days to Activate Windows 7
    Now you can install a Loader, and Reboot
    Windows Loader(x86/x64) by Daz + WAT Fix
    This is the loader application that's used by millions of people worldwide, well known for passing Microsoft's WAT (Windows Activation Technologies) and is arguably the safest Windows activation exploit ever created. The application itself injects a SLIC (System Licensed Internal Code) into your system before Windows boots; this is what fools Windows into thinking it's genuine.
    Windows Loader + WAT Fix (x86-x64) Main Features:
    Can be run as a standalone application
    Works well with all system languages
    Argument support for silent installs
    Can be used for pre-activation
    Application integrity checking
    It runs before Windows is launched
    Custom error handling
    It works with VMware, VirtualBox and Hyper-V
    It allows you to install custom OEM information
    Support for hidden partitions and complex setups
    Can work alongside Linux's GRUB or any other boot manager
    Works with TrueCrypt and many other types of hard drive encryption applications
    Add your own certificates and serials externally
    Offers certificate and serial installation only for users with an existing SLIC 2.1
    Automated system profiling (The application matches everything up for you)
    The rundown
    Compatible with Windows 7 SP1 and all system updates ***10004; check
    Will run on x86 and x64 systems ***10004; check
    No core system files get modified ***10004; check
    No extra processes are run so you have nothing eating at your RAM ***10004; check
    All key parts of the exploit are encrypted with a custom encryption ***10004; check
    The exploit runs before Windows so it's harder for Microsoft to prevent ***10004; check
    The exploit patches all necessary tables making activation look authentic ***10004; check
    The application will select the best profile for your system during installation ***10004; check
    Each and every user has a unique version of the exploit installed on his/her system ***10004; check
    Supported operating systems
    Windows 7 Ultimate
    Windows 7 Ultimate E
    Windows 7 Professional
    Windows 7 Professional E
    Windows 7 Home Premium
    Windows 7 Home Premium E
    Windows 7 Home Basic
    Windows 7 Starter
    Windows 7 Starter E
    Windows Vista Ultimate
    Windows Vista Business
    Windows Vista Business N
    Windows Vista Home Premium
    Windows Vista Home Basic
    Windows Vista Home Basic N
    Windows Vista Starter
    Windows Server 2008 Enterprise
    Windows Server 2008 Foundation
    Windows Server 2008 Standard
    Windows Small Business Server 2008
    Windows Storage Server 2008 Standard
    Windows Storage Server 2008 R2 Essentials
    Windows Server 2008 R2 Enterprise
    Windows Server 2008 R2 Foundation
    Windows Server 2008 R2 Standard
    Windows Small Business Server 2011 Standard
    Windows Small Business Server 2011 Essentials
    WAT Fix will:
    Uninstall RemoveWAT (or similar)
    Uninstall HAL7600
    Uninstall Chew7
    Uninstall uODIN
    Correct file permissions
    Correct important system files
    Correct services required for activation
    Correct VBS file associations
    Remove Microsoft entries from the HOSTS file
    Warning: Do not close WAT Fix while it's running.
    Note: You must be running build 7600 or greater for Windows 7 and Windows Server 2008 R2.
    Note: Not recommending using any of the Windows 7 E editions.
    Note: Windows 7 N editions will only be supported when OEM SLP serials leak.
    Note: Even if the icon is green someone might have found a way around the protection system so it's worth checking that the applications path is always the same as the location from which you launched the application.
    You should also check that the MD5 matches the MD5 found online.
    Language: English
    New Links : July 2012
    RUN AS ADMINISTRATOR
    Windows Loader 2.1.7 + WAT Remover 2.2.6 [7+Vista+Server] DAZ
    http://1337x.org/torrent/370604/Windows-Loader-2-1-7-WAT-Remover-2-2-6-7-Vista-Server-DAZ/
    http://www.nomaher.com/forum/index.php
    Windows Loader 2.1.7 By Daz
    http://1337x.org/torrent/371143/0/
    PM me if you have a problem with this or if my links go down.
    Last edited by zorba anton; 23rd July, 2012 at 05:41 PM. Reason: Updated New Links
  8. #53
    Pasig
    version 2.1.7
  9. #54
    Mar 2013
    Hi I'm Newer here, I having the same issues with u all and wanna ask whether the instruction is works anot?
    Besides, I have try to key in the command slmgr - rearm in the Command Prompt, but it do not reboot and it showed that it was not recognized
    Pls help I have to settle this because I felt it unconvenience
  10. #55
    Buffalo NY USA
    Just download and run:
    Follow the instructions.
    There is No Virus or Trojan!
    Tested and Working!
  11. #56
    Aug 2013
    Make sure that if you use Windows Update dont install the update KB971033 as it is part of the WAT and can disable the activation.
    Sorry zorba anton diden't see your post.
