Results 1 to 10 of 10
    Oct 2008
    Default Dreambox 800 password
    Can anyone advise please. Have just changed from a db500 to a db800.I bought this last year but have not used until I got to know how to use the db500. The 800 has CCcam 2.0.11 installed. I have connected db800 to my network and all is working fine. However when i try to use any dreambox tool and input the default user name and password ( root and dreambox)it fails to connect. Whats going on? Any help appreciated.
    DK Veteran freck's Avatar
    Jul 2008
    Dark side of the Moon
    If your dreambox is online and you need to use a dreambox tool youll have to switch off "dhcp" and use your lan settings to connect to it.Set your ip address to 192.168.1.XXX on your pc and have your DB at one digit less than pc address and try again.
    Freck
    Oct 2008
    Thanks for the reply but what I need is to be able to use DCC or Flash FXP amd these both need a user name and password.
    Apr 2009
    if you forgot the password
    and your image has no password reset
    you need to download via dm800 addons
    a plugin called Tuxcom
    which when installed becomes
    TuxBox Commander
    start TuxBox Commander
    scroll down to var
    OK
    scroll down to etc
    OK
    down to passwd and press 4 (edit) ( file name passwd not passwd- )
    OK on first line
    RED to clear line
    enter root::0:0:root:/root:/bin/sh with remote buttons like an writing an SMS
    OK
    EXIT
    save YES
    EXIT
    save YES
    EXIT
    EXIT
    EXIT
    then login with dcc or telnet ect
    login root
    no pass !
    Oct 2008
    Brilliant did this today and all works fine. Thank you.
    Mar 2011
    In any Windows version:
    Step1: Click Start
    Step2: click RUN
    Step3: type: CMD
    Step4: type: telnet 192.168.1.2 <-- that was an exemple write the ip of your Dreambox instead of 192.168.1.2
    Step5: It asks for user type: root
    Step6: It asks for password type: dreambox
    Step7: type: passwd
    Step8: type your new password
    Step9: type your new password again
    Step10: reboot your DreamBox and you have a new root password!
    Second Way:
    If you don't have windows or Command Prompt then you can use PuttyTel.exe (download link: http://the.earth.li/~sgtatham/putty/...6/puttytel.exe).
    Then continue from step 4 above.
    when i try this it goes straight into bios (does not ask for user or password)!!!
    how can i get it to ask for my password so i can change it plz??
    V.I.P. Member Curious123's Avatar
    Apr 2008
    Quote Originally Posted by lcc300 View Post
    On your pc do Start > Run > CMD in the black screen type in telnet yourboxip (Return)
    passwd (Return)
    It should then prompt you to enter a new password.
    Mar 2011
    Quote Originally Posted by Curious123 View Post
    passwd (Return)
    as soon as i telnet myboxip (return) it takes me straight into bios. i cant type passwd (return). whats your thoughts? plz
    Thanks Devo,
    This worked.Hurrah!!!!!!!!
    Oct 2011
    hello guys,
    i have a bigger problem.... i have no password or username for my dm800 and root/dreambox was changed and the box has a pin so i cant acess setup or bluepanel on dm. i heard of puttytel but it does work for me can anyone help please?
    thanks all
