Results 1 to 15 of 28
    Default astra h 1.7cdti turns over but wont start
    hi guys,
    driving along and car cut out,put a code reader on and it showed crank sensor,replaced it still wouldnt start(but does crank)have now tested all fuel pump,injection system,timing cambelt everything is fine.
    But just sent ecu off they found 2 faults fixed it,sent it back put it in still the same!!!! i dont know what to do,why didnt the computer show an ecu fault??
    weird i need some help!!
    many thanks
    Liteace's Avatar
    Mar 2009
    On a rock
    Scope the crank sensor, it maybe problem with bent or missing tooth\teeth on the crank.
    Meat-Head's Avatar
    Quote Originally Posted by Liteace View Post
    Better than that Jim, suggest the 'teeth' on the crank shaft have 'fell off'
    Liteace's Avatar
    Mar 2009
    On a rock
    "teeeth" fall out, they dont fall off
    Meat-Head's Avatar
    is another way
    Refusing to pay your invoive at M-H-M is also an option
    Refering to 'this' totally wrong image, but will do for what is a rumor going around
    racin-snake's Avatar
    Jun 2009
    the relluctor ring can become loose and move or teeth can break off seen it with a bent con rod situation
    but for this one in paticuliar
    what codes are you getting ?
    and with what are you reading it with?
    edu is a common failure on these as is derv ingress to the ecm
    worth looking at the codes you get can you post them?
    Today is the Tomorrow you worried about yesterday ......Was it worth it ?
    Default thanks here are the codes..
    the codes are p0335 crank shaft sensor malfunction,p0500 vehicle speed sensor malfunction abs/tc/esp.
    whats your thoughts on them??
    these were picked up on proper vauxhall tech 2,but if the ecu was faulty why didnt it pick that up?
    thanks for your help
    Jun 2009
    what i said was the edu suffers from problems .ie dry solder on relay for spill control
    and ecu can suffer from diesel ingress
    not malfunction
    the best and easiest answer to your faults is find out what the sensors doing in real time
    if it has a crank/cam sensor scope the both and look for tdc synchronisation
    also not entrely sure what engine or variant it is but
    if the edu goes down theere wil be no fuel suply to the injectors
    but will flag a code
    another thing is the reluctor is sometimes a matal strip round the crankshaft again i do not have a diag so shooting in the dark
    but this can vibrate loose and caus the reluctor to move around and take tdc out of sync
    also on tech2 you will have the option of guided diagnostics
    use tat to graph the crank cam situ
    again i am only trying to help
    racin snake
    Portugal
    Hi friend.
    To check if it is the cramshaft sensor you must do 1 of 2 things.
    In Opel cars we can see it without diagnose machine.
    first option - if you have diagnose machine put it in live data and see if it is reading rpm signal.
    second option - In opel cars when the cramshaft is not reading the rpm pointer in the dashboard doesnt move, if it reads it moves even if it is just a little.
    Test this way if no diagnose machine.
    Best Regards,
    Nuno
    Default thanks for your help...but..
    cheers guys
    when we put tech 2 on the crankshaft is reading giving a signal when turning over (200-300)which i persume means that it is picking it up although it showing as fault?
    racing snake when u refer to edu/ecu i take it u mean the same thing?its located at the front in the wheel arch(stupid place to have ecu!!??)if you was seeing a reading would u rule out the reluctor ring?
    what i did notice is when turning over there was little if none reading from the camshaft sensor when turning over which i have tryed a new camshaft sensor which does not make any difference but a solid reading from crankshaft.
    bizzare its driving me mad but all your helps are brilliant cheers
    Ashraf6119's Avatar
    UK
    Have you checked the Timing if its not jumped it could be one tooth out.
    Ash
    Thanks Ash
    Oh yes if my post was helpful than Please don't forget to press the Magic word Thanks
    Jun 2009
    can you give us full details ie engine code and year ect
    also unfortunately no the crank signal will still show if relluctor has moved it will just see tdc as a different position
    is cam sensor in the pump on this one ?
    full details would help a big bit
    as we cannot see or hear the car
    on other thing will it start with brake cleaner ?
    also ive seen these to have oil pump wreck completely vauvhall have a modified oil pump
    but if it were to seize then maybe it could have jumped a tooth on timing ?
    all in theory but an option
  13. #13
    Default cheers...heres more..
    Ok i have checked the timing/cambelt etc and it is spot on.
    have not tryed brake cleaner yet,what will this eliminate if it starts or does not?
    the cam sensor is at the top level with the ca**** the front as u look at the engine...
    When u say engine code what do u mean or where can i get that from?
    Thanks for all your helps any ideas will certainly help!!
  14. #14
    Jun 2009
    engine code should be in service book and on the engine too
    the ecu is at th top of the engine the edu is at the back of the engine at o/s drive shaft or there about's
    if you can give year ect it will help us to help you
    and brake cleaner will start this car if sprayed down the inlet manifold
    but only briefly as long term may cause damage
    post full details
    remember we cannot help with no info
    as we cannot see the car and diagnostics is one thing but doing it remotely is another
    post full details no need for vin or reg
    just engine year ect
  15. #15
    DK Veteran teuton's Avatar
    Mexico
    If really
    Quote Originally Posted by westy_77 View Post
    , then just go back to the basics; check compression, do a cylinder leak down test etc. BTW you didn' t put fuel in shortly before it stopped working?
    As recommended by racing snake please come up with engine details.
    Yesterday we stood in front of the abyss. Today we'll move ahead.
    If you need any repair manual, pm me- maybe I can help you.
