airmax (4th October, 2018)
can it also do multronic ?
magpro 2 is on special 1800 euro is not to bad but I can do all edc17..med17.5 ecu s with abrites in boot but cant do simos PR2.1 and dsg ,multronic flashes ,maybe I must by vagcan pro too then
Abrites ,full package
Carprog
Dajavue
Zedbull
orange 5
Tango
Vag-com
Vag Tacho
Vag Dash can
Vag Can pro
Magpro 2 X17/ FLEX
VVDI PROG /MB PROG
pay the price ...go original always works better......
solved the problems with the gearbox?
See selector lever....
There are 2 magnets.number 6-7 rear side check .
line44 (5th July, 2020)
edit that post !
Edit sorry
someone to know the parts number of the female connector for the Hytronic VL381F, VL300 ? I can not find it as parts.
Thanks in advance!
Nice 10x lagas.
Can you know the pinout ot this modul VL381F I need the supply terminals and the CAN Bus Terminals. Can I test it without the car with VAG COM?
Pinout i have needto find, but diag i thin only with can gateway or with some other devices.
hi meat -head looking for info regarding a a4 multitronic that has no PRNDS display and no communications with any other system on the car and seen your posts regarding these do you happen to have any ideas (looked inside ecu already ) and or wiring loom diagrams /test method to find cause of the issue
cheers in advance
Hello.. Is JP_Olli still here or somewhere tto caontact ?
Here you are mates - complete Multitronic wiring diagrams
Although data communication is provided via CAN GW it worked for me to hook up the CAN wires directly to my original VCDS VAGCOM . Just FYI
Vl300? Yes it works but vl381F? Any one tryed ? Because usually i flash vl381f on the car. Cant do it on bench. Immo is acvive
When repairing the Loose connections: Is it sometimes nessesary to solve on the board also or is it always only on the "frame" that the bad connections is ? And is it possible just to "heat up" bad connections Again or should I use som tin platet wire from "frame" to old Alu wire (and then cut a Little out from this)
Somebody have Photos ? because many of JP_Ollis links doesn?t Work anymore :-( ... Please helt, I should make this in the weekend and have studied all I can find.
