Results 1 to 15 of 21
    Default sagem SL 96 decode
    peugeot 306 1.4 gasoline sagem SL 96 decode
    any solution for decode this ecu?
    sagem sl96-9
    psa 9632520280
    sl96
    21649399-3
    ind.mod.:_e
    9307 406089
    i see in ecu tms 374 and 29f010a
  2. The Following User Says Thank You to rog3rio For This Useful Post:
    gmarvin (6th July, 2021)
  3. #2
    italy
    Default Solution
    It 'easy to do.
    You need a cable with a resistance of 100 ohms in series.
    Connect one end of the cable to ground.
    Connect the other end of the cable to pin 22 of flash and turn on the key ( Key ON state ) .
    5 seconds after disconnecting the cable and you should hear the stepper motor that moves .
    If not, redo the operation to pin 24.
    In this way we causes to microprocessor a 'Bus Error' which erases the EEPROM inside the micro and (on this ECU) the reset of 'im * o.
  4. The Following 9 Users Say Thank You to autorisp For This Useful Post:
    alexeybulatow (22nd May, 2020), Caarlosalfredo (10th August, 2020), capi (16th December, 2013), carlab237 (25th June, 2020), gmarvin (6th July, 2021), luizdoval (14th June, 2023), Meat-Head (24th May, 2020), runkl (25th February, 2017)
  5. #3
    Quote Originally Posted by autorisp View Post
    It 'easy to do.
    problem solved,but in pin 23 .
  6. #4
    is this all u do i have a sl96-9 on a belingo van and have been on with it for 4 months the tax is just about out os did it work thanks dene
    ROBERTby2000's Avatar
    in electronics
    It 'easy to do.
    is the same with sl96-1 Peugeot 406?
  8. #6
    Croatia
    i can t download pdf or pic
  9. #7
    Croatia
    I have SL96 and inside is 29F010,i try to connect on the pin22 but there is nothing happen,i try to scroll from the minimum to the maximum but nothing....
    so i don t know what to do now
  10. #8
    kautuvera's Avatar
    can you help me the X-PROG how to win or do I connect to tms 374 my wires
  11. #9
    MSolen's Avatar
    universe
    Quote Originally Posted by Mezz_cro View Post
    You are giving GND through 100 Ohm on:
    22pin flash memory - if you have inside 28F256
    23pin flash memory - if you have inside 29F010
  12. The Following 3 Users Say Thank You to MSolen For This Useful Post:
    alexeybulatow (22nd May, 2020), SPIROS2105 (19th July, 2016), Stelaras26 (2nd May, 2023)
  13. #10
    thanks a lot
  14. #11
    abidjan
    Quote Originally Posted by ggff View Post
    thanks a lot
    you just read the flash and then repiar whith immokiller
    and the car will start if not that means your car has another
    problem thn scan and see
  15. #12
    Quote Originally Posted by MSolen View Post
    i test this method in many cars never work for me!!!
    finaly i use the clock file.
  16. #13
    HI
    I have version SL96-4 with AT29C512
    How i can immo off this?
  17. #14
    DK Veteran magdex's Avatar
    POLAND
    I have the same problem ! 27C512 No one solution work !
  18. #15
    maaxxyy's Avatar
    North Pole
    Quote Originally Posted by Nabil1987 View Post
    Is the clock file for the tms or 29f010? If so could you supply a clock file? Thanks
