Can anyone provide me a code from a dump file? can read dump from BCI or Engine ECU, just tell me what you need. Just to clarify its the 5 digit code that normally comes on a card with a car (to program new keys etc to the bci)
thanks.
Rob
thanks.
Rob
have access to an MVP transponder copy system (where i used to work) so will duplicate my current key, its more for the remote fob and to make my indicators flash when locking/unlocking...
will read and post the dump. thanks.
cable for the BSI is missing, can you calculate from engine eeprom 95640? i think that holds the code too...
or anything else?
any joy with the vin?
rob
get a pin ?
did i get one you mean???
Can you get PIN from VIN? I bought a Stilo but last owner lost code card and now a can't make my indicators flash when locking.
you cant determine the PIN code from the vin with a calculator (like you can with Peugeot etc) afaik it can only be done via dump file from one of the ECU's, you can get the PIN from a fiat dealer though.
Hi JmAuto,
did you have any luck?
Just been reading the user guide for ICC, you can supposedly read the immo pin from the bosch engine ECU (IC 95640), the immo ECU (93c46, 93c56 or 68HC05E6), magnetti BCU type1 (HC912DG128 OR DG256), or type2 (95140)
so, my questions are:
- can anyone provide code from dump?
- how to tell the difference between type1/2 bcu?
- where is the immo ECU, i cant find it...
thanks.
oops still at the bottom... uppsies
just a thought, can any OBD connection (KWP2000 or similar) read the code?
bumpie... anyone?
