Results 1 to 8 of 8
    Newbie baracuda26's Avatar
    Default saab 9-3 airbag problem
    Hello m8"s
    I had a crash with my Saab 9-3 2006.
    I sent my airbag module for a clearing crash data.
    After when I recieved my module I make diagnose with LUNCH intertface:
    Total codes 004
    code 001:
    B1000 Ecu mulfunction
    code 002:
    ( ff.56,90,21, please refer to relevant technical manual)
    code 003:
    B0051 Deployment Commanded
    code004:
    B0053 Deployment Commanded with Loop Malfunctions Present
    I replaced airbags too (2,2 k)
    What should I do now?
    What this code means?
    Airbag light still on
    Please help
    Member doodgee's Avatar
    Aug 2010
    Quote Originally Posted by baracuda26 View Post
    Please help
    Hi, sry but what rezistors you used ?
    2.2 Kilo oms ? or 2.2 Oms ?
    because if you put 2.2 K it will not work
    Quote Originally Posted by doodgee View Post
    I think 2.2 Oms.It is work beacouse Lunch dont show any information about side airbag and curtain.He replaced many airbags so he know which one use.
    Maybe they (www.crashdata.co.uk) didn:t swipe crash data corectly?
    Any ideas m8?
    mcm44's Avatar
    This codes means that Crash Data (B0051 and B0053) is still present in unit's memory, and B1000 is exactly what it says: ECU Malfunction (Internal Error).
    Aug 2010
    Seams it's bad cleared module ...
    any idea ?
    Press THANKS if it's helps
    any idea ?
    Can I clear that modul using op-com interface?
    salerno
    HELLO
    POSSIBLE INFO FOR THIS FILE AIRBAG?
    OP-COM RESET THIS ECU?
    Mar 2011
    Default airbag saab 93 2006
    I need help to get this crash dump.
    saab 93 2006
    temic 12 77 12 36 W0 582219
    her2011
