Results 1 to 11 of 11
Thread: W32/BLASTER
    Nov 2008
    Default W32/BLASTER
    I have Window XP operating system.
    Above file tries to load everytime my daughter goes on the computer. I have disabled it but I want to get rid off from my computer. I searched on Google and it directed me to microsoft site which advised me that there was a fix with service pack 1 and it is not letting me download above sevice pack again. Any help would be appriciated. My computer has gone very slow. I have tried to scan with malewarebytes and AVG but it has not improved.
    blackburn
    Quote Originally Posted by koter002 View Post
    try formatting it m8
    Bulld0g's Avatar
    Apr 2008
    Liverpool
    What anti virus are you using ? Google your anti virus\ w32/blaster for a fix
    Nov 2008
    I have AVG but could not find any tool to remove it. Googled and forund symantec site which had removal tol. scanned my system which status no blaster workm found, but another message was detected by system. It is "%systemroot%\system32\dumprep 0 -u. his pro" which is trying to load. Any idea?
    dasteph's Avatar
    Nov 2008
    north east
    if you have usb flash drive and a unaffected pc try downloading clam av and installing it on the usb drive then scan your pc from the flash drive.
    ClamWin Portable | PortableApps.com - Portable software for USB drives
    janobi's Avatar
    Mar 2008
    In a field.....
    Sounds like the very old Blaster worm virus.
    You will need to end task certain things before it will let you get rid of it.
    Check for PENIS as a running process in task manager, you can download the blaster worm removal tool off loads of different AV sites.
    mcm44's Avatar
    And don't forget install a Service Pack 3. Blaster will be never back...
    Nov 2008
    Thank you for the advice. I have alredy installed service pack 3 on my computer and I cannot find the process in task list you have mentioned above.
    I was informed that the fix was in service pack 1. I am trying to delete and install service pack 1 if possible. Another solution is to make my daughter as administer and then download any removal tool but I am afraid that Blaster may do some damage because I have read that if is infects in Adminstration a/c then it wil cause lot of damage. At present I have disable my daughter a/c and advised her to use guest a/c which I have created for her until I am sure I have removed Blaster from her account.
    mcm44's Avatar
    Service Pack 1 and 2 are included in Service Pack 3, so you don't have to uninstall SP3, to install SP1 - this makes no sense at all...
    Manual Blaster/MSBlast/Lovsan removal instructions:
    AVG Free - Worm.Lovsan | Remove worms from your PC
    or just download the free removal tool from:
    W32.Blaster.Worm Removal Tool | Symantec
    E. Yorks. UK
    Empty your internet cache and temp files - a common hiding place.
    This is a useful utility for internet and temp file cleanup.
    CCleaner - Optimization and Cleaning - Free Download
    It may also be a good idea to remove windows restore points as virii often hide here and pc can be reinfected when a restore occurs.
