Page 13 of 23 FirstFirst ... 389101112131415161718 ... LastLast
Results 181 to 195 of 338
  1. #181
    securipro38's Avatar
    EU
    HI
    I know now that there several commands to type on ddt2000 to see isk code like 10a0 and 21d8 or 10A0 and 21FF but now ,I'd like to know which command to type to see isk on fallowing cars
    RENAULT LAGUNA 2 /PH1 2002 912DG128
    RENAULT LAGUNA 2 /PH2 2006 ( CAN ) I know that I must have can cable and simple kkl won"t work
  2. #182
    Apr 2011
    Romania
    21DC is for Laguna. Anyway screens defined in xml's show you ISK code without sending manual request (UCH M2S Phase2 and UCH M2S X73 et X74) . That is for Laguna2, Espace4 and Velsatis.
    See Antid et acces screen.
  3. The Following 2 Users Say Thank You to gabigafu For This Useful Post:
    jeanalvitre (4th April, 2019), martinracing (30th November, 2013)
  4. #183
    EU
    Quote Originally Posted by gabigafu View Post
    Ok thanks I"m going to try and give results thanks a lot
  5. #184
    EU
    HI i CAN SEE isk without manual request as you said
    Can you tell me witch manual request to send to Megane 2 /PH 2 plase
  6. #185
    Apr 2011
    Romania
    Quote Originally Posted by securipro38 View Post
    Hi , sincerely I don't know it, becase I have not original interface to work on CAN, but try different commands 21FF, 21DC, 21D8, must be something like that 21xx and UCH must answers with 61xxyyyyyyyyy.
  7. #186
    EU
    Thanks for your answer
    I will proceed to test it from 2100 to 21FF ,225 solution and will report on a magane 2 / Ph2 which I already know pincode and gives you result
  8. #187
    Apr 2011
    Romania
    if you try manually start from 21FF to 2100
  9. #188
    Hi all.
    Need APV Laguna 2 PH1 912DG128
    ISK: 16 C5 B3 D0 9F 38 (got via .xml not via manual request)
    Tried APV: 4F 9C 0B 62 D9 E8 (not working @gabigafu)
    also tried: 32 B1 C7 A4 EB 4C and 40 93 E5 86 C9 6E
    and can't enter APV mode in DDT2000.
  10. #189
    62B1C7A4EB4C this is your APV
  11. #190
    62B1C7A4EB4C tried, i wrote 32 instead of 62 sry
  12. #191
    if you have SBB try with it
  13. #192
    Don't have. Want to figure out this in ddt
  14. #193
    V.I.P. Master of the IMMO
    lupu_sandu's Avatar
    Far far away
    What .xml did u use to get ISK? Best way:
    Get ISK via Manual Request only, get APV, learn cards.
    Enter APV in DDT when no card are inserted in card reader
  15. #194
    uch m2s x73 et x74. isk via manual request (21DC) is same.
    EDIT:
    Tried to enter APV mode in different lagunas (912DG128) without success. No card in reader of course. It seems that apv code is wrong. Dont know. Any clue?
    Couple of ISK and APV tried:
    ISK: 95F9F9B03CA3 APV: E18D8DC448D7
    ISK: 01B6787DB29E APV: 75C20C09C6EA
    ISk: 672C023A32DE APV: 1358764E46AA
    Request to enter apv mode sends correctly, no errors received but apv mode is still inactive.
  16. #195
    EU
    Quote Originally Posted by Snh View Post
    EDIT:
    same problem like you ,tryed about 10 laguna 2 could see isk with ddt2000 and converted apv
    Tryed with SBB and always said wrong pin.
    Tryed also with clip v60 ,same problem .
    Apv converter seems to not work with laguna 2 with DG128
