Results 1 to 15 of 19
    dimitar's Avatar
    Default BMW ADS interface
    Here is the ADS schematic. I hope someone can share the dump for GAL16
  2. The Following 3 Users Say Thank You to dimitar For This Useful Post:
    kest (4th June, 2024), NikoF (4th December, 2020), petdej (4th April, 2023)
  3. #2
    dimitar's Avatar
    Here it is OBD-ADS without GAL tested on E34, E36, E38, E39, E46, E60. Works perfect with inpa. DS2_1 and DS2_2 goes to ground to activate OBD , left unconected works as ADS
  4. The Following 2 Users Say Thank You to dimitar For This Useful Post:
  5. #3
    cipijoint's Avatar
    here is jed file for the Gal 16v8 needed in the ADS interface.
    do you have gal programmer? u can build one if dont have one, there is also schematic for gal programmer.
    the file is archived with 7z .
    dont talk a lot and nothing
  6. The Following User Says Thank You to cipijoint For This Useful Post:
  7. #4
    cipijoint's Avatar
    by the way, i dont think will ever work without gal.
    The schematic interface with max232 can work on bmw over 1995 , but under this year especial e34 , e30, e32, never ever.
    if you need to buy some real ads interface, good quality and cheap price, can find in Poland.
  8. The Following User Says Thank You to cipijoint For This Useful Post:
  9. #5
    dimitar's Avatar
    I use carsoft for models under 95 ,no live data no coding anyway you dont need anything more than carsoft . For gal programing you can use this home made programmer http://www.armory.com/~rstevew/Publi..._ClikMe1st.htm
    50w Soldering Iron
    Chisel
    Sometimes Hammer
  10. The Following User Says Thank You to dimitar For This Useful Post:
  11. #6
    This scheme is a more modern ADS
  12. The Following 3 Users Say Thank You to svid For This Useful Post:
    NikoF (4th December, 2020), petdej (4th April, 2023), RC211V (4th June, 2022)
  13. #7
    Quote Originally Posted by svid View Post
    Is it for E30 Models too ?
  14. #8
    Can someone share pcb file for ADS interface ?
  15. #9
    Nov 2010
    Default BMW diagnose
    hi,I am interested for BMW diagnoses
  16. #10
    What is ADS. I'm trying to obtain information about this system but there's not much availibal.
  17. #11
    Dec 2010
    Is it for E36,318is,M42 Models too ?
    Work with INPA,GT1 DIS?
  18. #12
    Feb 2011
    how much cost ADS interface for professional diagnose for INPA or DIS ?
  19. #13
    Jan 2011
    Wink BMW Programming difference ADS / OBDI
    I'm an newbie and have been trying to work out the differences for programming BMWs using a laptop.
    What I have worked out so far is:
    1) ADS is an expensive BMW optical interface.
    2) OBD interface is a 'cheap' method but not as advanced, but is also standard for many cars. So that is what I am looking at as there are plenty on e-bay using INPA/EDIABAS.
    Using OBDI - you can use BMW DIS for diagnostics and SSS to do programming. However many forums suggest 'NCS Expert' as a simple tool for making simple changes to default car settings. e.g. enabling/ disabling Day driving lights. Anything more ADS is the way.
    It would be good if a cheap ADS method were available.
  20. #14
    Yaroslavl
    - BMW EDIABAS: STD:OBD
    - BMW EDIABAS: ADS
    - BMW EDIABAS: D-CAN (STD:OBD K + CAN)
    - BMW EDIABAS: JBE PT-CAN (STD:OBD + JBE CAN 500k)
    - BMW EDIABAS: JBE K-CAN (STD:OBD + JBE CAN 100k)
    the best interface
    tieCAR.net Company - Products
  21. #15
    Apr 2011
    Default ADS
    THX! finally I found this schematic and dump.
