I want to cut a steel scaffold pole to shrten it,, what kind of tools will i need? Im not going to do it myself, dad will do it if he can get hold of th tools![]()
Read the Rules here; they apply to Everyone.
___________________
In the good old days, I hadDM800s HDOpenbox S10
TM500
DM500s
90cm FortecStar dish
Technomate 2300 Motor
I would use a small angle grinder with a 4" cutting disc, make sure you/he wears protective clothing ie; gloves & goggles at the least.
use a still saw and goggles
Grinder or hacksaw.
Hacksaw would be simplest way. Disc cutter fastest. 9" angle grinder would do it. 4" grinder won't cut all the way through (unless you turn the pole as you cut it).
All of the above or pipe cutters. A few twists and turns and the jobs done.
The best thing to use is a angle grinder as it will cut it like butter..
I would not bother with a hacksaw as you will be there all week, just to cut a small line..
So just invest in a angle grinder it will make life alot easier in the long run.. As scaffey poles are quite strong steel.......
Hope this helps you out............
you can get one dirt cheap from B@Q for about ?10
Just nip in an engineering/fabrication shop near you...they'll do it for nothing!
