Results 1 to 9 of 9
    Jun 2009
    Default Delphi ecu pinout BDM connector
    Seek pinout and descrypion pin BDM connector for Ford Dephi 4S71 ecu and pinout china BDM100 to read MPC
    Satmanek,
    you have photos of the board of the ECU?
    attach to the post please.
    Jun 2009
    This some Bildelphi Ford.jpg - OBD-Wiki a i know pin 1 and dont know name other pins. Firt step with BDM. For test XProgM read MPC5xx.
    Download this User manual BDM100 , it's in there.
    Jun 2009
    No, in this manual write where is pin 1, how connect oryginal cable, where is power ecu, ect... Where is pads DSCK,DSDO,SRST,PORST,DSDI... signal ?
    Yes. If your Delphi BDM pads are not mirrored, they should conform to the Motorola BDM standard pinout found in the almost last page of the document. The pin 1 will guide you to all the rest pins.
    Don't know the ECU pinout but the clear photos may help.
    DK Veteran rappttor's Avatar
    PERPETUUM MOBILE
    dont try to experiment on it, it is true, wiki gives the location of pin1, but the rest can be switched, and if you dont know for sure the pad arrangement, you will f..k the ecu up for sure....
    so if someone tested it yet feel free to share the info
    regards
    ps: if you still want to experiment, just a sugestion, dont let the bdm to vcc the ecu, use ecu vcc...
    DK Veteran elchip's Avatar
    EU
    Quote Originally Posted by rappttor View Post
    regards
    Yes never supply ECU from BDM and if you connect wrong dSO , DSI and CLK it is not problem only communication did not work..
    Regard's
    [I]Automotive Electronics Solutions
    Mercedes-Benz Reverse Development Engineer ...
    Mercedes CFF 2010-2017 CFF all models all modules
    Vediamo help flashing over teamviewer ...
    JLR SDD online + offline ...last official ...
    Dec 2010
    Default OK connection DELPHI 4S71
    Never too late
  10. The Following 3 Users Say Thank You to jaelgti For This Useful Post:
    brane0001 (6th September, 2020), capi (7th November, 2015), F4kk3r (21st May, 2014)
