not sure if this post is in the right place but here it is, i try to download wii iso's from newsgroup servers but nearly all of them fail to download 95% of the time. anybody have any info on this please.. thankx in advance..
What news server are you using, what is its retention, and what is happening when they fail? Have you tried quickpar etc?
im using newsdemon, 600+ retention, and it says
Message is no longer available on the server
Thats odd. I can only assume the files you are attempting to get are too old for the server. I use nzbsrus, which is very up to date, and you can set the retention in the settings.
OR
Newsdemon is blocking certain binary's such as alt.binaries.wii, but i doubt it.
i use usenext they have a download wizard so any rar that does not download properly it uses quick par to self repair. but you can do it manually go to where you downloaded the iso and download any par files that are there and repair the damaged rar files ... you will have to download quick par if you already haven't
Super.Mario.Galaxy.2 which fails is only 12 days old it says. using bin search..
im not getting any files downloaded atall caddy40, its just not a case of files need to be fixed..
That file doesnt work for me either. i can post you a working smg2 nzb if you want., infact no i cant, i cant add attachments on this forrum. go reg at nzbsrus or what aver the guy above uses, get proper nzb's instead of troulling through binsearch.
its free(ish).
., this fails aswell m8
look up usenext.... you get a free trial for 7 days 3gb fast download free and unlimited slower speed never had a problem with usenext all the files are retained for 1 year... and they have all the games you are looking for...will cost you about ?10 for 25 gb download each month well worth it though ....
ON A USENEXT trial, good so far....
I've tried every super mario galaxy nzb on nzbsrus and all faili'm using astraweb and never had this before.
newsdemon is spot on never had a problem 50 connections 608 day retention + two ssl servers for ?12.00 a month and i can down load no problem at full speed 50 / 55 mb![]()
