Results 1 to 12 of 12
    Top Poster kingy999's Avatar
    Nov 2008
    Default fiat bravo 1.6 16v , over heating problems ???????
    hi
    i have got a fiat bravo 1.6 16v , it starts fine , but its overheating ?? the water and oil are not mixing , but its been sitting for 18 months ? is there a special way of bleeding it ??
    the heaters inside the car are blowing cold , even when the dial is on hot ??
    many thanks
    smirnoff_rules's Avatar
    Mar 2008
    birmingham
    theres a bleed nipple on the heater pipe at the rear of the engine m8 .. a black plastic circle , unscrew and run and topup water till it runs out and put back in
    Nov 2008
    there a couple of bleed nipples i think mate. the heater matrix gets clogged up on these mate. try blasting it clear with jet wash
    Meat-Head's Avatar
    Quote Originally Posted by smirnoff_rules View Post
    OOPS. Unless getting confused. Check if there is one on the radatitor
    Also change thermostat, just next to the battery, big bulbus thing
    did one 2 weeks ago, fat smelly bloke not been back yet.
    Sep 2008
    thermostats more than likely has failed i would replace it,was the water level low if not stat has stuck.
    dopsleutel13's Avatar
    Dutch
    As the heater cold is and the engine runs hot, then the fan on the water pump will be separately touched.
    Sorry for the translation.
    Liteace's Avatar
    Mar 2009
    On a rock
    Could be anything, I had an astra-f the other day, bottom of rad bellow where fan switch screws in had all this brown clay like shite in it so a 3rd of the rad wasnt being used, changed the rad and it was a liitle better untill it over heated again. I pulled the head off and every waterway between head and and block was blocked with a hard brown shite, hammer and screwdriver to remove it. I also pulled the waterpump off and the impeller was completely corroded away
    Junior Member matekk's Avatar
    Jun 2009
    guys have said you plenty of things what to do,i was have once such car and i was replacing coolant and the same thing happened to me,try to replace thermostat and through the niplles bleed the air out of the system. it would take some test drives but in the end it would be okay.
    E. Yorks. UK
    Quote Originally Posted by Liteace View Post
    I owned an astra F diesel which developed the same symptoms as you mention was having to top up radiator with about a litre of coolant every week although it never overheated, eventually pulled the head off to find it had cracks between the cylinders had to fit a new head - megabucks.
    As to the Bravo, Fiat engines are notorious for air locking the cooling system and for heater matrix to clog as already said.
    Perseverance when filling is the only way and it can take some time to expell all the air.
    Also does this have an electric fan and if so is it cutting in?
    I have the instructions some where for filling the cooling system on an Punto Mk1 and I think the procedure is similar on all of these fiats.
    I will attach it as soon as I find it if it is of any use to you
    Liteace's Avatar
    Mar 2009
    On a rock
    The best thing to do when you fill it is open all bleeds and then put pressure tester on filler (header tank or rad) and make sure all the bleeds are bleeding
    or had the same problem head gasked burned
    Thermostat deffo!!!! The matrix wont get clogged by sitting but the stat will suffer.
