Results 1 to 11 of 11
    Default peugeot 407 2.0 hdi will not start
    hi i have a peugeot 407 2.0 hdi, it will not start its seems to be stuck in economy mode?
    engine ecu:
    permanent fault. control unit *internal fault
    permanent fault. brake contact signal main switch fault
    permanant fault. fuel pressure signal open circuit or short to live +ve
    perminant fault. rail pressure sensor supply voltage too low
    perminant fault. pedal sensor supply voltage too low
    bsi:
    boot fuse box: rear left brake light fault, short circuit to positive. local
    tryed both keys its not immo fault also new recent battery, helpppppppppppppppppppp
    Hi there, did you check battery connections? Carry out drop voltage test while cranking, you might have loose ground strap or lazy or shorted starter motor, they used to become crap with time.
    There is also a possibility one or more ECUs have become spiked if you try to jump start it not following safe procedures. Check fuses on BSM under the bonnet, always let BSI go into sleep mode by leaving car alone for at least three minutes before disconnecting battery.
    And fix your brake light short to rule things out, you never know.
    DK Veteran cars's Avatar
    Italy
    If you have not used peugeot original test, you must be sure that the definition of faults stored are correct, because this reading would seem the ECU died, because she is feeding sensor rail, foot and pressure regulator.
    Of course before replacing ECU check it
    power supply and grounded.
    If help you remember to push the button thanks !!!
    Top Poster Porelo's Avatar
    Reads the parameters and checks if it has any value outside the normal, the answer is there.
    Porelo
    i checked it earlier and the radio and electic windows was working again so i guess it is not in energy saving mode any more, but it just turns over and will not start (if i spray a little brake cleaner in the air intake it will start for a few seconds), i will make sure all earths are ok, check fuse banks, do a voltage test, check fuel is pumping, and parameters test, we have peugeot planet i will take a look tomorrow and let you know how i get on, thanks for your help guys
    Ashraf6119's Avatar
    UK
    Quote Originally Posted by seano123 View Post
    engine ecu:
    bsi:
    Your this two fault codes are pointing towards your problem,
    Check your fuel filter, Injectors leak, Fuel Pressure Sensor etc etc...........
    Hope This Helps.
    Ash
    Thanks Ash
    Oh yes if my post was helpful than Please don't forget to press the Magic word Thanks
    Default still no luck
    tested battery steady 12.76v cranking at 9.97v, all earths intact, sorted rear light problem, no leaks, fuses ok, parameters check nothing really to tell as the engines a no go everything zero (see pic), have replacement fuel filter to fit tomorrow, where would i find the fuel pressure sensor? and also where do i find the fuel enertia cut off switch if it has one? thanks for your help guys
    racin-snake's Avatar
    Jun 2009
    there is a presure sensor under the fuel rail at between cylinders injector pipes at gearbox end look underneath the rail
    also make sure your bsi is reset
    try doing a soft reboot with batt at at least 13v
    do a global test to see actual code nos and definitions then post these
    Today is the Tomorrow you worried about yesterday ......Was it worth it ?
    cant see the sensor theres 2 much in the way, tuesday i will take off parts and fit a new sensor, if that dont work its going to a specialist, will let you know what it was tho, thanks for your help
    Italia
    Hello see this problem almost certainly is the ECU burned, open it and see if there are tracks saltate.A me with the same car and then the same thing ....
    ecu has been tested and been told its dead beyond repair, the only way is a new ecu and egv valve and some other part to put it right? they also said you cant program a used ecu? is there any way round this, thanks
    ECU SIEMENS 5WS 40167F-T
