Results 1 to 9 of 9
    Default Vectra stiff gear change when warm.
    My Vectra has suddenly developed a strange fault, basically when at running temperature the gear change becomes very stiff i.e the gear lever doesn't return to the neutral position when i've droppped out of 1st, 2nd, 5th or 6th. It is the F40 6 speed manual box, and so far I have changed the gearbox oil (putting in th reduced amount recommended by TIS) and the gear linkage cables. My next option is to remove and grease the gear selector shaft, which looking at TIS looks quite an easy task. Has anybody else undertaken this and what grease would you recommend me to use?
    sweden
    Default it's
    Quote Originally Posted by tramman View Post
    the linkage cables vaux... got a special toll to adjust thoose
    The linkage cables are adjusted correctly, there's no issue of selecting a gear (no notchiness) it's just stiffness in the movement of the lever and the lever returning to neutral once at running temperature (again no issue when cold).
    DK Veteran dimitar22's Avatar
    Jan 2009
    When you drained the oil was there enough oil according to specifications, and there were any metal shaving on the magnet on plug?
    Nothing at all on the plug, and the oil was spot on for the original spec, however when refilling i put the revised amount in which definately made the gear change smoother. The gear selector according to tis is just a case of removing three bolts and tilting it to the left to remove, is it really that easy?
    i had a saab in with same problem it was the selecter part that fitted in box there is a rivot that part of the linkage pivots on it took me about an hour to free this off with the linkage part in the vice
    hope this makes sense
    tony
    Member marc7's Avatar
    Aug 2010
    Leeds
    when i refilled mine after fitting dmf n clutch i was told by my vauxhall technician mate to overfill by a pint and its been running like that with no probs
    Quote Originally Posted by tonyboy101 View Post
    tony
    Was the selector part easy to remove? My only worry is that I remove it and discover I can't get it back in.
    Quote Originally Posted by marc7 View Post
    The F40 6 speed suffers from syncro problems with 3.2 ltrs so vx recommend you only put in 2.4 ltrs. This correct from the VX tis.
    Signum 2004...,Vectra-C 2004... Z20NET| Z19DT| Z19DTH| Y30DT| Z30DT,Z20NET| Z19DT| Z19DTH| Y30DT| Z30DT
    Complaint: Hard 1-2 shifting when transmission is cold, 2-3 shift when transmission warm.
    Cause: Design related.
    Production: The reduced oil level was introduced in production starting 08.05.07 with the following VIN:W0L0ZCF4871102355.
    Remedy:
    In case of customer complaint reduce oil volume from 3,2 to 2,4 liter.
    Can anybody recommend the best type of grease to lubricate the selector once I have removed it and cleaned it up.
