Page 5 of 23 FirstFirst 1234567891015 ... LastLast
Results 61 to 75 of 331
Thread: 4.3 mod
  1. #61
    ck-ok just got home from work did what u said but there is no option of boot to system hack in MMM
    please help as i am now getting in the neck from her in doors the kids will be next :-(
  2. #62
    only have 15 hacks is this right ?
  3. #63
    just read that if u rename the bootmii folder on your sd card to bootmii_old it will boot the wii system menu, did it and it worked and i now can accsess the priiloder page yee harr all good i think now on to back up discs!
  4. #64
    if i rename the bootmii file will it still load priiloader and prevent updates ?
  5. #65
    h,i getting dvd error 1167 when i try to load cod in neogamma using vabatum and ingburn, wii will paly backup dvds(movies) have done a search but nothing came up. the game is ntsc version but i have enableld any region. any help would be graetfully recived
    thanksin advance
    mike
  6. #66
    V.I.P. Member ck-ok's Avatar
    nottingham
    Quote Originally Posted by dynomikered View Post
    thanksin advance
    mike
    im sure the wii can't play wet fish .
    anyway are you using dvd-r verbatim and burning with imgburn at slowest speed.
    as for movies http://www.digital-kaos.co.uk/forums...ies-wii-96949/
    how old is your wii if its newish you may have a d3-2 drive that cant play backup games or movies so you may have to use a hdd or usb pen
  7. #67
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Quote Originally Posted by ck-ok View Post
    oops so youv'e updated to 4.3 and you want to remod your wii or mod it for the first time then follow this tut for 4.3e/u
    first your gonna need to install homebrew channel to do that you will need one of these games Indiana Jones Original Adventures(ntsc-u/pal) -4.3u/e
    or
    Super Smash Bros Brawl(ntsc-u) -4.3u
    format sd card to fat 32
    Use a standard SD-Card, 2g or less
    download the hack from here Digital Kaos - Downloads - 4.3 hack files and unzip Hackmii_0.8_IP_SS_BB2.zip, and put on sd card
    then follow this if you using indiana jones
    Works with 4.3u/e
    -Play Lego Indiana Jones Original. Start a new game and complete level one with the nunchuk attached then make a saved game, then exit to System Menu.
    -Go to wii settings, data management, save games, wii, SD
    Delete the Lego Indiana Jones Save Game.
    -Click SD, copy Indiana PWNS for your region
    -Play Lego Indiana Jones original without the nunchuk attached load save game slot 1
    When the game loads, you will be in Barnett College. Walk to the Art Room (through the Courtyard), approach the left character on the podium. When it zooms on him, choose the switch to option (two silhouettes, staggered, with an arrow pointing between them).
    this will start hackmii installer.
    if your using super smash brothers brawl then do this.
    Smash Stack - Works with 4.3u
    -Load SSBB ntsc, with sd-card removed, make a save file if asked
    -Go to the stage builder, delete all custom stages found, exit the stage builder
    -Exit all the way back to the main SSBB menu
    -Insert SD-CARD, Go back to the stage builder
    -HackMii Installer loads
    now you can install homebrew channel and bootmii
    Read the Scam warning and press 1
    It may take a minute or two for the "press 1" to appear- be patient
    Install the HomeBrew Channel
    Install Bootmii as Boot2(boot2 may not be available, IOS installs automatically)
    Prepare the SD-card
    now you need to do a nand backup
    Load HBC, press -HOME-, launch Bootmii
    Make a nand backup
    Press Power, Power, Power, Reset, Reset (or use gc-controller)
    Power = Right, Eject = Left, Reset = Select
    this thread willhelpif you need more info http://www.digital-kaos.co.uk/forums...loader-109168/
    make sure you save these to your pc for safe keeping
    nand.bin
    bootmii
    keys.bin
    format sd card again and extract modpack from the folder you downloaded earlier to sd card
    run md5summer.exe and click verify sums and check theres no errors
    now you need to install your wads.
    Start HBC, press [HOME], Launch Bootmii
    Multi-Mod Manager Starts (via cboot2)
    Never Uninstall IOS, you will brick your wii
    Select "WAD Manager" - Press A
    Press (1) to "Install all Wads" - Press A
    19 wads should install without issue
    "Press any button to continue"
    Be sure all the wads install, very important
    If the wads fail to install, install 1 at a time
    Press B two times- main menu
    thats it nearly finished just need to install priiloader
    You should now be at the main menu of Multi-Mod Manager
    Select "App Manager" -press A
    Select priiloader -press A
    Read the warning- Press +/A to install -if needed Hold B press +/A to install with cIOS
    After priiloader installs, it may freeze during restart- this is ok
    Hold reset and boot wii while holding reset- priiloader will load
    Select "System Menu Hacks"- Press A
    Enable "Block Disk Updates", and "Block Online Updates", others if you like
    If MMM loads at boot, select Manage Priiloader, Edit Priiloader Hacks, enable needed hacks.
    If you don't know what the hack does- you don't need it.
    Your wii should now block Disk updates and online updates
    Note: Prilloader installer gives two errors-
    /loader.ini couldn't delete error -106
    /password.txt couldn't delete error -106
    this is not a problem just carry on
    thats it done
    what part of the process is used when you have a machine with
    D2sun & Softmod on 4.1e
    many thanks
  8. #68
    nottingham
    teerak2uk what is it you wan't to do,just update your softmod?
  9. #69
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    just get it to the latest possible setup i had even thought about ditching the the d2pro and going for flatmii or same sort of thing as i was told that if i update to 4.3 all i will lose is the ability to play ntsc on my pal machine
  10. #70
    Nov 2010
    Having a bit of a problem today with rar files.
    I am trying to unrar a Wii game file that has been compressed to around 187mb.
    When I click on the file using winrar I expected it to appear on the desktop as a iso file at 4.37gb but all the shows up is a winrar archive file at 4.37gb. I have magic iso installed as well
    Then when I click on this file it pops up
    The archive is either in unknown format or damaged
    Is there something i've not done correctly as i've tried this on a number of game files with the same results??
  11. #71
    nottingham
    Quote Originally Posted by Bones77 View Post
    proberly just a bad image,
  12. #72
    nottingham
    Quote Originally Posted by teerak2uk View Post
    if you dont want the loaders then install all the wads except neogamma/loadmii/usbgx/cios70 and cios80 if you want them then all of them except cios70/80. and loadmii.
    i would recommend making a nand backup before installing.
  13. #73
    Jan 2009
    Guys can someone please offer some advise I have a wii with version 4.3e and a hardwired chip fitted.
    When the Wii is fitted with a chip whats the next procedure ,how do I go about installing the homebrew channel does anyone have any instructions to follow?
    Can I downgrade this 4.3e Wii to a lower level firmware to be able to play other region games?
    Thanks for the advise
  14. #74
    nottingham
    Quote Originally Posted by shagx View Post
    softmodding is just the same as a normal wii,follow the tut from here http://www.digital-kaos.co.uk/forums...-3-mod-157379/ once you have modded it the you can downgrade too 4.1
  15. #75
    Jan 2009
    thanks for the pointer so are you saying I need to go and get the Indiana Jones Original Adventures game to be able to mod my chipped wii?
