Results 1 to 15 of 23
Thread: CLIO KEY U9280M
    DK Veteran snecii's Avatar
    Default CLIO KEY U9280M
    I have a CLIO key I want to change immo chip in it!
    But I can find any chip like this: U9280M
    I see a lot of this in renault keys but I dont know the name of it! It is like the 7946at you have to solder it!
    Where can I buy it? how do they sell it? It not like ID46! Or it does?
    Top Poster ajondyh's Avatar
    U9280M is a microcontroller with embedded transponder interface which is designed to operate remote as well as RFID.
    In UK Hickleys sell them. They also sell them at codecard.lt and a few Chinese sites. They need to be pre coded with data before they will program into a car.
    I have U9280
    look at this.
    I would also be interested in any progress you make.
  5. The Following User Says Thank You to albertros For This Useful Post:
    martinracing (20th November, 2014)
    What file type is this?
    Hi, its develpoment software for a development board.
    Part numbers on the opening sheet.
    Here is a link to the data sheet. http://www.atmel.com/dyn/resources/p...ts/doc4591.pdf
    The demo board is about ?500 or $500 outside the UK
    Someone must be able to make something that will interface the pc to the chip, any offers ?
    PierreTheron's Avatar
    Centurion,South Africa
    Can Zed bull pre code these u9280 from dump in uch to start the car.????
    Pierre
    I have oe zed bull but not the eeprom upgrade
    I understand zedbull can re use old keys
    First you program immo then remote then combine the 2.
    I keep asking for someone to send me the dump for the 93c46 to learn the remote part but no luck yet, anyone?
    Tmpro will do half the job as usual programing the immo but not the remote
  10. #9
    Default 93c46 dump
    Scenario
    Renault clio 1
    All keys lost??????
    H ave got new remote key ordered from vin number at renault by customer but they could not get it programmed to car.
    I think someone did an ecu set replacement - thats why key is wrong ordered from vin.
    Here is dump for 93c46.
  11. #10
    Feb 2011
    Quote Originally Posted by PierreTheron View Post
    Scenario
    Renault clio 1
    All keys lost??????
    Pin is 3954
    33 logic to start car:
    30 00 00 00 FF 8F FF 00 00 00 38 0E 00 00 7E 00
  12. #11
    the pin number 3954 is for the car. If the new key was made for another car it should be possible with zudbull to make immo work, then do same with remote then combine the 2 dumps butas I said I don't have the upgrade to do this with zedbull.
    You can make a T5 work the immo part. I havn't checked but I suspect its the dump above. As for the remote part ??
    If you make a T5 you will need to remove the ant in the key, just get the T5 working with the blade to start if you go down that road.
  13. #12
    Default clio1 93c46
    Quote Originally Posted by workdamnyou View Post
    Pin is 3954
    Thanks for reply .
    Do i need a new key or can the new key that i have be recoded.
    What tools do i need to get this car to run ???
    ( Do not want to do immo off , I would like to get the key to work on this car)
    Thanks in advance
    Ps ...Have tried to add key with the pincode with MVP but does not work..
    Pierre
  14. #13
    Feb 2011
    If you write the above logic to a T5 transponder the car will start. You will need something to write the transponder though...RW2/3/4, AD900, Zedbull ect....
    If you dont have one, most shops that clones keys can write it for you.
  15. #14
    Have got T5 chip here i think, will check...
    Have got Gambit clone( been lying around for 6 months),
    Will set it up and try with that.
    At least car will start.
    Have got about 6 0ld keys here. Most with U 2980m and 2 with pcf 7946at on them.
    (Waiting for Zed Bull clone )..
    Have got time to play with this vehicle , so will see how it goes .
    Pierre
  16. #15
    Gambit clone does not support this i think (to write to T5).
    Will have to wait for other tool.
    I see that i can order pre coded key by vin number from 3D Group. ( Will not help because i think there is other ecu set in this car)
    Will wait for Zed bull first and try that way to make certain car starts.In mean while i will immo off another sirius 32 i repaired and see if car runs.
    Will give outcome off this..
    Last edited by PierreTheron; 28th February, 2011 at 05:33 PM. Reason: Edit spelling
